Nuprime Stream-9 Questions
esiu
« on: 21 Aug 2023, 11:30 pm »
I'm a new Stream-9 owners & wondering if anyone occasionally hears a slight stuttering while streaming using Qobuz?
Also, I would appreciate it if you could share your experience with non-stock power cables and fuses.
TwymanJ
Re: Nuprime Stream-9 Questions
« Reply #1 on: 22 Aug 2023, 01:26 am »
I've had a Stream 9 for a couple of years, use it exclusively to stream Qobuz through the Omnia app, and have never had an issue.
Like most things, I think it benefits incrementally from connecting it with a decent power cord, without getting stupid for the price point. I haven't tried an aftermarket fuse.
Hope that helps.
rustydoglim
« Reply #2 on: 22 Aug 2023, 06:16 am »
Nuprime factory power code comes with a choke that suppresses high-frequency electronic noise.
Instead of buying a high-end power cord, invest in Pure AC-4.
esiu
« Reply #3 on: 22 Aug 2023, 10:38 am »
Hope that helps.
Thank you.
esiu
« Reply #4 on: 22 Aug 2023, 10:54 am »
Thank you for your advice. I'm using Audioquest Niagara 1200, which significantly improved my entire system, including my old Volumio Primo streamer, and I hope it does a similar job as Pure AC-4.
Have you experienced the stuttering issue mentioned above with your Stream-9 while using Qobuz or Amazon Music? My old streamer does not have this problem in the same network.
Fenek
« Reply #5 on: 23 Aug 2023, 09:16 am »
Last year I had similar problems with Qobuz HiRes tracks.
After the last Firmware upgrade ( 4.6.439250.52 ) all problems are gone.
rustydoglim
« Reply #6 on: 23 Aug 2023, 09:32 pm »
If you still have the problem, please contact [email protected].
esiu
« Reply #7 on: 25 Aug 2023, 07:30 pm »
Yes, my Stream-9 runs the same firmware version you mentioned. Thank you.
esiu
« Reply #8 on: 25 Aug 2023, 07:31 pm »
Will do, thank you.
