I have no experience with these, but the amp camp amps (ACA) is popular on diyaudio.com and diyaudiostore.com.
There's the newly released Musical Fidelity A1, 25 watts of class A, circa $1,500 but no balanced inputs.https://www.musicalfidelity.com/products/a1
Nice, thank you. The balanced input is a luxury, not a requirement. Just thought if I’m going this route I’d lower the noise floor as much as possible.
I own a Pass Labs X250 amp and use balanced inputs. I can hear no difference between the balanced and unbalanced connections. Just use good RCA interconnects that are well shielded.Personally, I would consider an AVA Vision 120 Control amplifier or Vision 120 power amp.
I have ACAs. They are a really good amplifier for the money (and just good regardless). They are quite versatile especially if you have a pair. Bridged, paralleled, multi-amp.Aegir is well regarded i have yet to hear one. Stodart uses some clever trickery to get this AB amplifer to perform much more like Class A (no GM drop).If you are building do not forget the ACA mini. I prefer a single of this to a single ACA. I may be soon getting another and i will jerry-rig balanced in and see how they perform.My main amp is a Firstwatt SIT-3. Unobtainium now, really, really good, but unless you diy a Firstwatt is out of your price range.Monarchy audio makes a 25 w Class A amplifier that is very good, jst a bit over a grand. A single man operation so not a lot of overhead.Sugden may satisfy. your need, likely need to find a used one (price) and it will be an integrated. If you diy, your options explode. Check out the Pass forum at diyAudio.com.Do pay attention to the amplifiers output impedance. Bridged ACAs have similar to an SE tube amp, Aegir near enuff to zero. If the loudspeaker has a poor/wild/non-flattish impedance curve the high output impedance amplifier will interact with that. I do not have a high opinion of either of the loudspeakers your mentioned.dave
I DID look at the Vision 120 power amp. I’m intrigued.
what speakers would you recommend?
...the MOFO mono power amp...
As far as the amp(s), I was thinking of building 2 mono Amp Class Amps.
