Solid State Amplifier to drive Lii Audio F15
0 Members and 1 Guest are viewing this topic. Read 5799 times.
Jon L
Re: Solid State Amplifier to drive Lii Audio F15
« Reply #20 on: 11 Nov 2023, 05:40 pm »
Consider Neurochrome Modulus-86 amp.  Unbelievably neutral and transparent.
https://neurochrome.com/products/modulus-86-stereo-kit
jk@home
« Reply #21 on: 23 Feb 2024, 12:53 pm »
I'm using a W4S M-Pre (with a fixed volume setting) and dual M-Amps on my Xizi Fast 15s. Balanced Mogami interconnects, and Analysis Plus Oval Nines speaker cable. Same setup I used for the previous KEF LS50 setup, not your stereotypical high efficiency equipment. No noise coming out of the drivers and sounds great. I use a Mini DSP  SHD Studio upstream as the preamp, which has a very fine volume adjustment. I had also tried a 2 watt tube amp, went back to the class D.
Heres another who used W4S with their OB:
https://www.enjoythemusic.com/RMAF_2016/Holt/Wyred_4_Sound_PureAudioProject_Spread_Spectrum_Technologies.htm
