PH 9.0X balanced operation switch
0 Members and 1 Guest are viewing this topic. Read 2118 times.
Stefan_DR3
« on: 9 Aug 2023, 01:57 am »
First of all, is there a user manual for the PH 9.0X?  The 9.0 manual doesn't get into this.
I have a 9.0X on loan and I'm testing it with both RCA and XLR outputs (separately of course).  I am using only the MC input.
There is a switch on the back, between the XLR sockets, that is not labeled but it appears to affect the grounding of the RCA/XLR outputs.
1) The XLR outputs work regardless of the switch setting.
2) I read that this switch should be set to RCA when using RCA outputs, which I am assuming is the DOWN position (?).
3) When the switch is in the UP position, the XLR output level changes slightly (+1 dB) but the MUTE selection no longer works.  Also the MONO switch does not work (there is only a slight change in the sound but it remains a STEREO sound).
4) When the switch is in the DOWN position, all functions work as expected.
Stefan_DR3
Re: PH 9.0X balanced operation switch
« Reply #1 on: 16 Oct 2023, 04:47 pm »
@Modwright ?
Bones13
  • Happiness is a choice
« Reply #2 on: 29 Aug 2024, 01:20 am »
Manual says that switch switches between XLR or RCA output, and that only one is meant to be active at a time. It’s on the web page. If yours is acting differently, I would contact their support, again via the web page.
