Sound Quality of Nuprime Stream-9 Output Interface
0 Members and 1 Guest are viewing this topic. Read 4795 times.
esiu
Which output interface of Nuprime Stream-9 do you prefer, COXIAL or AES/EBU? Thank you.
avdg
Re: Sound Quality of Nuprime Stream-9 Output Interface
« Reply #1 on: 16 Aug 2023, 05:10 pm »
The AES/EBU and the hdmi I2S output can handle the higher quality. I would use these higher rate outputs and only if the DAC doesn’t support that use the coax.
If the source stream is not of the highest quality you may not notice any difference compared to the coax output. Normally the technology for the higher quality is pushing the envelope wrt SNR and jitter and that advantage is always there but doubtful if you can hear it.
Not sure if this helps … otherwise extra context/info wrt your question may help.
BR
esiu
« Reply #2 on: 19 Aug 2023, 09:36 am »
Thank you.
