Worry about which pressings later. For now just listen to the music. First and foremost, let your ears decide.When you find something that really speaks to you, they you can find the pressing you want. For me, music I love on a mediocre recording beats a great recording of something I don't like any day of the week. Hope you find some value in the lists and recommendations made here.
Thanks Tyson, that should take quite awhile to go through. Hopefully I may have a better idea of what I prefer. I am not a drinker, but as I understand it most start drinking desert, sweet, wine, and somehow doing so over time changes their palates, and in time the development an appreciation for dryer wines. I imagine that classical music may take a similar cultivation to truly appreciate much of it. Thanks again. I hope to start digging in on Sunday. I am still trying to decide which of 2 amps I prefer. One, speaking of wine, is quite full bodied, the other may be more refined. I won't have that sorted out by Sunday, but classical may make the differences pronounced enough to make the decision easier. BTW, if you know someone getting started in audio, and who likes full bodied, less detailed but quite livable music, I just bypassed the crappy Muse caps in a Lyr, pre/headphone amp with .01uf Duelund copper foil bypass caps. While it isn't perfect, it's something that I could actually live with now. I highly recommend it for anyone who has one, or needs a moderate costing preamp that is able to punch well above its cost. I'll likely use that too, just to check it out with headphones. The caps have less than an hour burn in, so it will likely still improve too.
Oh, absolutely. I only buy used gear, and then proceed to mod the hell out of it Duelunds are great caps, as are Miflex copper.
Easy, get the latest version of Don Sachs' DS2, he may have 1 left, bypass the ODAMs with CuTF V-Caps, and run that into a neutral SS amp, the best of both worlds.
...Here's a full list of all the amps I own currently. Some people roll tubes. I roll amps. Haha, it's maybe a little out of hand....First Watt Burning Amp 3 (BA3)First Watt Aleph JDon Sachs "baby-Kootenay" KT66 Push-PullCustom EL84 Push-Pull (based on ANK EL84 amp)Dennis Had Inspire MB14 Single Ended Pentode Monoblocks Almarro A318B 6C33C SETTAL Korneff Type 45 SETElekit TU 8233 2a3 SET and 300b SETSun Valley 211 SET and 845 SET
Whenever I had an amp question I used to PM BigRedMachine... but you may be the new amp fanatic! I've only got two modded Moscodes, three Dodds, and a Folsom. Oops, and sort of a Dynaco 120 with better iron, caps, circuits, and KT120 tubes. Maybe you're not such a fanatic after all.
Actually, one of my power amps is a custom design that Don Sachs helped me with. I wanted something like a Kootenay but with KT66's instead of KT88's. It was a 1 off build, and I'm super happy I have it as I like the KT66's a lot more than the KT88's. Here's a full list of all the amps I own currently. Some people roll tubes. I roll amps. Haha, it's maybe a little out of hand....First Watt Burning Amp 3 (BA3)First Watt Aleph JDon Sachs "baby-Kootenay" KT66 Push-PullCustom EL84 Push-Pull (based on ANK EL84 amp)Dennis Had Inspire MB14 Single Ended Pentode Monoblocks Almarro A318B 6C33C SETTAL Korneff Type 45 SETElekit TU 8233 2a3 SET and 300b SETSun Valley 211 SET and 845 SET
