How to Start a Purist Audio System
0 Members and 2 Guests are viewing this topic. Read 32571 times.
Re: How to Start a Purist Audio System
« Reply #20 on: 7 Jan 2024, 02:36 pm »
Start by educating your sense of hearing.  Music appreciation classes are a good place to begin.  Listen to unamplified music in places with good acoustics.  Get your hearing checked.  No point in spending gobs of money if you can't hear.
Set a budget.  Good systems that serve medium sized rooms can be had for $1000 retail, but won't go super loud or deep.  Avoid DIY that leads to proud papa bias which all audiophiles are guilty of anyway.
Setup your listening space.  As I mentioned above the room shouldn't be squarish, small, or uninsulated.  Ideally it will be dedicated to listening.  My room is 8ft x 13ft x 21ft and well insulated.  It has a fiberglass exterior door with weather seal and flexible ductwork (can't hear the furnace).  It is treated with ten GIK 244 2ft x 4ft absorption panels plus three side wall tall bookcases (diffusors) that I can vary the "design" to suit.
Spend considerable time auditioning (months/years).  In many cases this would involve traveling, make a vacation out of it.  Bring 10 or more varied selections of what you love, including an audiophile guilty pleasure (poor recording) as the system needs to serve your desires.  Take written notes.  Only audition in a space that's similar to your room, not an open/noisy space.  Audition complete systems.  Insist on in-home trials.
JohnR
« Reply #21 on: 8 Jan 2024, 02:02 am »
It would probably be helpful to begin by defining what a purist audio system is.
I can think of two definitions which lead to completely opposite approaches:
1. Focus on the hardware. This is FRM's approach. No crossover, simple circuits (except for the later comment about Class D, which surprised me), no boxes.
2. Focus on the result. This means measurements and (in my opinion and experience) active+DSP. But it's a longer road. Still, if I were starting again, that's where I'd start.
« Reply #22 on: 8 Jan 2024, 03:04 am »
The summer is too hot for a tube amp, I forgot to consider that.
artur9
« Reply #23 on: 9 Jan 2024, 02:49 am »
Start by educating your sense of hearing.  ... Listen to unamplified music in places with good acoustics. ...
This, a thousand times this.  Otherwise, it's akin to making a space travel movie in the forties, when no one knew what the Earth looked like from orbit.
https://www.thespacereview.com/article/3470/1
HST, electronica runs afoul of the "unamplified music" touchstone.
MC275V
« Reply #24 on: 4 Mar 2024, 08:10 pm »
As a longtime audiophile and music enthusiast, I feel that a “purist” system can be quite different for each person.  I also believe that your audio listening preferences can and will change over time.  If you listen to your system (or systems) often and enjoy it, you shouldn’t worry about it being purist.  I started my audio journey in the late 1960s with a Fisher tube receiver, ElectroVoice speakers and a Garrard record changer (which I only used manually for 33s).  By the mid 1970s I had moved to a solid state Sherwood receiver, Technics direct drive turntable and Sansui speakers.  By the early 1980s I had moved to Stereophile approved equipment, including HarmanKardon Citation power and preamp, Rega turntable, and Fried speakers.  By the 1990s I had B&K power amp, Musical Design tube preamp and Energy Pro22 Connoisseur speakers.  Today it’s McIntosh 275 amp, McIntosh C2200 pre, Clearaudio table, Harbeth speakers etc.  I’ve enjoyed each system throughout the years.  It’s been a fun experience for the last 50 plus years and I still listen every day. So, how to start a purist audio system; listen to live music, listen to as much equipment as you can, then purchase what you enjoy can afford.
sircrashalot
« Reply #25 on: 30 Oct 2024, 01:44 pm »
Hi to all,
I'm new to this forum and chose this circle to introduce myself because I'm always looking to improve my system's sound. I have been in the audio hobby for about one year, and as you might guess, already have a small collection of integrated amps, receivers, and of course, assorted speakers... most are second-hand and picked up locally. Every time I think I have an excellent sounding system, I find something that increases the SQ, although usually in small increments. Sometimes there are trade-offs: sometimes more clarity and detail at the cost of a little perceived bottom end, for example. I hope to learn more from you all. Thanks.
AllanS
« Reply #26 on: 31 Oct 2024, 01:23 am »
This could get to be an expensive hobby for you.  Welcome aboard!
Jon L
« Reply #27 on: 31 Oct 2024, 06:49 am »
Careful shopping locally is a great way to build a nice system without spending audiofool money (and STILL not happy :oops:).
If I were starting out today, I would go modular and separate bass from treble/mid.  For example, start with bass module using a vintage Alnico 12"/15" bass/mid driver with separate enclosure for treble/mid.  Reasonable Altec/JBL, etc horns with good compression drivers..
JimBobWay44
« Reply #28 on: 7 Feb 2025, 07:40 pm »
This is a very true statement; I have found my best bargains for some excellent gear on Facebook Marketplace and Craigslist.  But buyer beware, be sure to audition the equipment in person before plunking down a dime.
marcos overload brazil
« Reply #29 on: 10 Feb 2025, 01:25 am »
good tips
I.Greyhound Fan
« Reply #30 on: 10 Feb 2025, 06:00 pm »
I would start by going to stores and audio friends if you have them and listen to as much gear as possible.  Write down or make a mental note of what you like and do not like.  Bring along music when you go listen.  Also consider your tastes in general tone like neutral, slight warmth of even slight brightness.  Pick out speakers first and then match electronics.  Also, as others said, consider the room and where the speakers are going to go.  This is probably the most important thing.
I would also see if there are any local audio societies or clubs that have meetings as many audition gear at the meetings, plus you may meet some nice audio people and be invited to listen to their gear.  See if there are any local audio people on audio forums like this one.  There are several forums as you may know.
Then keep things as simple as possible.  I am not a fan of using separate amps to drive woofers and tweeters.  I do like separate components but I will eventually be selling my amp and preamp and move to a high end integrated for simplicity.  Something like an Ayon tube integrated.
« Last Edit: 10 Feb 2025, 07:08 pm by I.Greyhound Fan »
danvillesignal
    • Danville Signal
« Reply #31 on: 10 Feb 2025, 06:29 pm »
Welcome to the journey! There is no one path - you will need to find your own.
In addition to some of the previous tips, I would try to attend one of the high end regional shows. You will see a lot of gear, meet a lot of like minded folks, and probably have a great time.
The Tampa show is coming up very soon and Axpona (near Chicago) is in April.
In the EU, there is the Munich high end show in May.
As a manufacturer of gear, I am going to avoid the info commercial, but I do hope to see you and other newcomers at Axpona. The circles on the site are great examples of things you might see at the aforementioned shows and certainly not the typical Best Buy stuff.
Al Clark
Danville Signal
satishjasti
« Reply #32 on: 25 Aug 2025, 05:24 am »
I am newbie to the music world want to build system with eversolo DMP-A10 + AMP-F10 +speakers, any suggestions?
« Reply #33 on: 25 Aug 2025, 02:31 pm »
A purist system would have the fewest components.  Active monitors come to mind, with built-in amps that match the drivers.  Fit the speakers to the room.  Hopefully your room isn't small or squarish.  Setup is important too.  I prefer mid-field with speakers and listening position well removed from walls.  Like others have mentioned audition a wide variety of speakers and take notes (forces you to seriously listen).
Bodhi
« Reply #34 on: 25 Aug 2025, 02:36 pm »
darti
« Reply #35 on: 30 Dec 2025, 08:13 am »
Hi new members,
In view of many new members asking which equipment to choose to his system I put in this thread some basic guidance according my personal taste on how choose equipment to set up a Stereo audio system.
1) Always prefer hi sensitivity speakers and benign flat impedance as 100dB and 8Ω, hi sensitivity speakers dont cost more for that and work well with a small tube amps, a 101dB Klipsch RF7 will need about 10W SolidState and can run with a 45/2A3 SET tube amp at 1.5W, but many audiophiles buy speakers with less than 90dB that will need hundreds of Watts to drive a inefficient loudspeaker, it can stay worse if the speaker are 4Ω impedance. If you buy a 3-way Magnepan 84dB 4ohms (3 ohms most of the freq range) and you will need a expensive 500W Solid State monster amp.
2) Don't go down the HT route, stay on the purist audio road for better sound quality.
3) If possible stay Cross Overless with a big Full Range driver as Lii Audio F-15($399 pair) or F18($520/pair), if you need hi SPL use a pro-audio Full Range driver, but if you prefer a speaker with crossover dont buy 3-ways speakers, take a simple 2-ways speaker with a Coaxial driver as Beyma 12KX 98dB, 300Wrms, dont walk run from top tweeters.
4) Enclosure are there only to made bass, if possible use OB with hi QTS drivers 0.9 or higher.
5) Dont let paid magazines reviews and audio sites plenty of advertisers brainwash you.
6) Famous brands means high profit margin ratail price.
7) Read books from Ryder or Tomer on audio tubes, some are free PDF online.
https://www.tubedepot.com/t/other-stuff/books
8] If possible take a basic electronics training to guide you.
Hi, I am new here and woud likr to know if anybody got experence with building a good listening room himself?
« Reply #36 on: 30 Dec 2025, 04:00 pm »
Built a listening room in the basement 20 years ago (laws of physics haven't changed much since then).  Started with the Fibonacci ratios (5/8 ratios), limited by ceiling height to 8 feet, so the other dimensions were 13 feet and 21 feet.  Used insulated staggered stud walls, insulated exterior fiberglass door with weather seals, and insulated ductwork (could barely hear the furnace).  Walls/ceiling were drywall to mimic what I'm familiar with.  The room was spooky quiet for the first few days until I got used to it.  Ended up adding GIK 2ft x 4ft 244 panels but frankly they did little good in a near ideal room, but worked wonders elsewhere.
« Reply #37 on: 30 Dec 2025, 11:36 pm »
Never built a room or house, but I also recommend that you use the Golden Ratio proportions 1 x 1.618 x 2.618 or the Golden Trapagon from Cardas.
https://www.audiocircle.com/index.php?topic=107352.msg1183456#msg1183456
rodge827
« Reply #38 on: 31 Dec 2025, 12:19 am »
Ok so you have laid out your opinion for the “start” of a purist system. Where does it end?  :scratch:
« Reply #39 on: 31 Dec 2025, 03:40 pm »
FRM:  if you do the math, you'll find the Cardas numbers are 5:8 ratios.
Another purist approach is the analog path:  single driver speakers, small tube amp, and turntable.  But tubes age, vinyl is limiting, and single driver speakers almost always have limited bass.
The digital approach is much more forgiving:  active speakers have matched power amps, and online sources have limitless options.
