WTB : Good tube amp to mate with Spatial M3's
0 Members and 1 Guest are viewing this topic. Read 611 times.
2bigears
« on: 6 Jul 2023, 04:43 pm »
 :D time to purge the box speakers a trim excess gear. An integrated would be very nice as 1 box done. Open to ideas.  I listen to old time rock and roll. So much good gear out there. Live on Vancouver Island so Florida won't work,  ha.  Thanks all AC'ers.  A good crowd here. So much knowledge  :D
morganc
Re: WTB : Good tube amp to mate with Spatial M3's
« Reply #1 on: 8 Jul 2023, 07:21 pm »
What's your budget and room size and volume that you listen to?
For Rock I'd suggest getting a higher powered amp depending on your room size.
morganc
« Reply #2 on: 8 Jul 2023, 07:25 pm »
There are several LTA Ref 40's for sale on USAM.   Also the Carver Crimson amps mate very well.
If you can find one the Don Sachs Valhalla would certainly be my first pick.  He's in Canada also so perhaps ask if he has parts to build another.  You can't go wrong with any of those three and though they are different they are all winners.  The DS has more tonal density than the LTA.  The Carver is very good for the Price and runs very cool.
