0 Members and 1 Guest are viewing this topic. Read 2888 times.
I had my model numbers incorrectlooks like the E50 is what you recommended ...which is not compatible with the P50 power supply
Why not? the P50 has a 5v output and the E50 comes with a 5v USB to barrel cable so that you can use the E50 with a USB charger.There is the slightly more expensive Topping D30 Pro which has a built in power supply.https://www.youtube.com/watch?v=ubmAyGuSJt0
What are you using to power the E50I see they just released an E30 ii “lite” with only one AKM chip for $99
Regarding the volume control on these DACs (e50 or otherwise) … obviously at these prices one can’t expect a miracle in terms of ultimate fidelity, but in day to day operation and and low to moderate levels, what is the experience like relying on the Topping volume attenuation?
