Industry Circles
NuPrime Audio
rustydoglim
STA-9X / ST-10 XLR and/or SE Input
AllanS
28 Jun 2023, 10:31 am »
The STA-9X and ST-10 have switches to select either SE or XLR inputs. Can both inputs be connected at the same time (not powered at the same time) and the switch used to select between one and the other? It would be interesting to be able to select different pre amps in the system without needing to swap interconnects.
Thank you.
rustydoglim
Facilitator
Re: STA-9X / ST-10 XLR and/or SE Input
4 Jul 2023, 04:35 pm »
It wasn't designed as a switch. It will work, but having two inputs grounded together even when one is not active, could affect the sound. Worst if you accidentally turn on both inputs.
AllanS
Reply #2 on:
5 Jul 2023, 04:39 am »
Thank you. I appreciate your help.
Industry Circles
NuPrime Audio
rustydoglim
