Dynaco PAS Volume Control
0 Members and 1 Guest are viewing this topic. Read 1624 times.
Mark Korda
    • Dawkus
« on: 27 Jun 2023, 02:26 pm »
Dear Frank,
     I'm using a Dyna-35 you fixed up for me after I made a mistake.I love it! I have a preamp ,a Dyna PAS 3 that I want to take out the balance control on  and just use the volume. I don't need the balance as I adjust my listening position accordingly. There are 3 wires that go to a 2/250K pot. Red/right, green/left, and black/ground. I'm going to send you a picture of the pot on my tablet,it's not on this computer. It has a little circuit board soldered on the pins to make connections easier and clean. The way the manual has a pictorial diagram with the balance control included,I can't seem to figure it out. I still cherish Audio Basics and want to show you something I discovered while using your AR-XA turntable mod....thanks so much and you can't miss the picture of the pot I'm going to send, sincerely. Mark Korda
