On hunt for new a phonostage
toocool4
« on: 26 Jun 2023, 01:01 pm »
I have been thinking of upgrading a few things in my system for a while, what I am looking to upgrade are phonostage, pre-amp and speakers.
I had a few phonostages in mind to try out, the ones I had in mind are the Esoteric E-03, Rega Aura and the Zanden Model 120 to replace my Rega Ios.
One of the things I require from a phonostage is that it must have the controls / loading on an easy to adjust dial on the front panel, no dip switches.
When I upgrade as a rule of thumb, I need to be spending at least 3 x what I am replacing else it’s no point, you must consider inflation the price of everything has gone up else I am only making a sideways move to something different and not a true upgrade.
Checking out these phonostages they have all now gone up in price, which make most of them a little less attractive. The Esoteric has gone up about £3K and they have just stop making them since the E-02 is out, the Zanden has gone up about £3K and the Rega has gone up about £400. They become less palatable since they are not improved versions, they are still the same things but just cost more.
Anyway at the moment, I have the Rega Aura on a home loan so I can try it in my system. I never buy anything anymore unless I can have it at home and use it in my system in my room, that is the only way you truly know. You only really know what the kit is doing, when you have lived with it for a while. I find an hour or 2 in the dealers dem room to be a false evaluation, you may be wowed in an hour or 2 but when you live with it for a while you really know.
Out of the box, the Aura is an improvement in all areas over my Ios. After a few notes you can just tell, I did do a few switch back and forth then I stopped to just live with and enjoy the Aura.
I would not say I heard anything I did not hear before, but first thing that I noticed was how much quieter the phonostage is. I could hear everything better than before, the sound stage was deeper and wider, clarity was on a different level.
I have been playing my records, throwing many different tracks at it to see how it handles them. It has done a very credible job with most tracks.
People say this phonostage is revealing and yet forgiving at the same time. I would agree with the revealing part but the forgiving part, I disagree with it is brutal on not so good recordings.
A couple of tracks that it was brutal on is 12” mix of Grace Jones – Me! I disconnect from you and the other I have found so far is E-Z Rollers – Droppin Science, when the bass drops it’s painful to listen to.
I may be able to fix this issue buy doing a better setup, but we shall see.
I am still playing around with the capacitance to see if I can hear which setting sounds best.
Build quality the phonostage is built like a tank.
A friend of mine was here listening to the phonostages with me, we both came to the same conclusion an improvement in every area over the Ios.
So looks like I will be buying a new phonostage.
Ios on right and Aura on left.
« Last Edit: 29 Jun 2023, 10:02 pm by toocool4 »
rollo
  • Rollo Audio Consulting -
Re: On hunt for new a phonostage
« Reply #1 on: 26 Jun 2023, 03:32 pm »
  If within your budget try a Modright. If your frugal a Vista. Not a dealer for them.
charles
toocool4
« Reply #2 on: 26 Jun 2023, 06:06 pm »
Hi rollo
Thanks for pointing out the Modright, its a valve phonostage I stay away from valve as they are high maintenance. I always leave all my kit on 24 x 7 x 365.
Thanks anyway.
Bob2
« Reply #3 on: 26 Jun 2023, 07:29 pm »
Take a look at Goldnote for a phono stage. I have the PH-10 and am quite pleased. The PH-1000 is the next step up.
The Goldnote is easy to adjust, none of the tiny switches. Ton of adjustments. very intuitive to operate and make adjustments on the fly.
I use mine for two arms and it works great. Has single ended and balanced outputs.
https://goldnoteusa.com/phono-stages-2/
toocool4
« Reply #4 on: 26 Jun 2023, 07:47 pm »
Hi Bob2 I did think of Goldnote but the dealers I went to only had the PH-10 which was about £1100, below my budget. If they had had the PH-1000 I may have tried to have a look.
I am still not 100% going to buy the Rega Aura, so I am still on the hunt I may end up in a different place altogether. If I don't see anything else, the Rega Aura is the top contender at the moment.
Thanks for your suggestion.
P.S. Since I only use MC, I don't really want to buy something with MM built in. I think that is money diverted into something that is not needed by me, I just think if I am paying the money I would like to think they have put all the money into what I am going to use.
qdrone
« Reply #5 on: 27 Jun 2023, 03:08 am »
Give Whest a look at. Go to their website and look for B stock at a discount. I bought my Titan Pro there 7 years ago but since sent it in for the coil up grades. Fantastic phono pre amp,quality build.
« Last Edit: 27 Jun 2023, 02:16 pm by qdrone »
toocool4
« Reply #6 on: 27 Jun 2023, 10:14 am »
Hi qdrone thanks for your recommendation, the Whest don’t meet my criteria of having the settings on an easy to access front panel.
qdrone
« Reply #7 on: 27 Jun 2023, 02:15 pm »
I must have missed that. Good luck in your search. :popcorn:
toocool4
« Reply #8 on: 26 Jul 2023, 10:12 pm »
With everyone talking so much about the Lino C, I have been reading up on it. I am liking what I read.
I called Channel D to see if they have a UK distributor so I can borrow one to try out at home, unfortunately not.
After spending some time on the phone with Channel D, asking all sorts of questions about every aspect of the phonostage. When I finished I asked for the name of whom I was talking to, so when I email them I know whom to reference. I was surprised to find out I had been talking to Rob the designer himself all the time. I have to say the guy is very nice and helpful and answered all my questions.
I think I am about to do something, I never do which is to buy something blind without having listened to it in my system first. They have a 30-day money back guarantee, but since I am far away I cannot take advantage of this. If I pay the money, it’s a one-way trip so I better like it. Just making up my mind now whether to go for it or not.
I am looking at getting the one with the Current mode and the Voltage mode, that way if my cartridge does not work well with the Current mode at least I can use the Voltage mode. That is a $995 optional extra, but better safe than sorry.
Lino C review https://www.stereophile.com/content/channel-d-lino-c-33-phono-preamplifier
toocool4
« Reply #9 on: 27 Aug 2023, 06:15 pm »
Only Just plugged in the Channel D Lino C 3.3 phonostage today for a quick listen, liking what I hear so far.
qdrone
« Reply #10 on: 27 Aug 2023, 06:36 pm »
Let it settle in for 200 hours of music then report your opinions. Enjoy.
toocool4
« Reply #11 on: 27 Aug 2023, 07:03 pm »
It already sounded better after about 30 minutes.
toocool4
« Reply #12 on: 16 Sep 2023, 06:21 pm »
I have now been living with Channel D’s Lino C 3.3 transimpedance phonostage for about 2 weeks.
I had to wait for it as they are built to order, equipped with the specification you order.
It arrived double boxed. I opened the boxes to the sound of something rattling around, not a good sign. I opened the unit to find 3 screws rolling around, i figured out where they came from. By looking at that I figured one more screw must be somewhere and low and behold, I found the fourth screw. Not happy about this, I emailed Channel D and followed up with a call the following day.
Rob from Channel D answered, after he figured out where the screws came from, he was very apologetic and offered to send out replacement screws and brackets the next day if I am happy to replace them myself or send the unit back. I opted to have new brackets and screws sent out.
He did explain what had happened and yes his explanation was plausible, I did say to him I was surprised QC did not pick this up before it went out the door. He assured me this is a one off, I believe him.
Anyway, that over and done with, I got down to the fun part listening.
I plugged it in and left it for a good 30 minutes while I listened to music on the Rega Ios.
I switched over to the Lino C using the Voltage mode, the first thing that came across was the quietness, the wider / deeper soundstage. Everything sounded more believable the vocals / high frequencies were clearer, the sound was punchier.
I switched back to the Rega, so I can go from the Rega back to the Lino C using the transimpedance section of the Lino C. Wow, going to the Lino C using the transimpedance part of the phonostage was an ear opener, the music sounded more real is the only way I could describe it.
So now that I know the Lino C is better than the Rega Ios, now is the time to compare the Lino C’s Voltage mode against the Current mode.
I played tracks to compare both the Voltage / current mode. The voltage mode appeared punchier which I put down to the higher gain. Using the voltage mode, with the volume knob at 9 o’clock on the current mode I had to wind it up to 11 o’clock to get about the same volume.
Anyway comparing the 2 modes, the music coming out of the current mode was just more real / believable than the music coming out of the voltage mode. That’s not to say the voltage mode is bad, just that the current mode is that much better. I prefer the current mode sound.
To get the best from a current mode phonostage the cartridge’s internal resistance should be as low as possible, some people say in the single figure range. My cartridge has an internal resistance of 24 ohm, the Lino C should apparently work with up to 40 ohm resistance but the lower the better.
Since the current mode sounded better to me, that is what I am going to use. I only had the issue of the volume from the turntable being much lower than the rest of the other sources.
I must remember to adjust the volume knob if I am going from one source to the other, else I will get a nasty surprise.
Some days later I remembered I can change the gain setting in my pre-amp, so I have now gone into the pre-amp and turned down the gain settings by 6db on all the line-in except the turntable input so now everything matches.
One of my friends came over to have a listen to the new phonostage.
I started by playing the Lino C since it was hooked up then the Rega, he liked the Lino C.
I then played the Lino C again, now going between the current / voltage mode. I did not tell my friend which was what, he correctly identified the current and voltage modes. He preferred the current mode like I did.
Rating the Lino C
I have to say on build quality I would have to rate the Lino low and on sound quality, I rate it very high. So overall I would recommend the Lino C, but I hope in the future they keep an eye on their QC and build quality.
I have played some records using the phonostage, but not as many as I would like as I have been busy. The other reason I had not played as much is one of my drive units on my speakers is on the way out, it distorts badly when a low bass note is played and that side sounds louder.
Before I worked out the issue, I had already decided to buy new speakers.
Doing a lot of tests like changing cables round so moving left cable to right to see if the information moves, nothing moved around.
Then I worked out it was the drive unit on the way out.
I then pushed on the drive units, I noticed the suspension on one of the drive unit is gone. The faulty one moved too freely and the other gave me more resistance. When playing I can see the drive unit was out of control and moving wildly compared to the other drive unit.
I have placed an order for Peak Consult Sonora plus I have placed an order for 2 matched pair drivers for the broken Peak Consult Princess Signature, I still want to be able to sell the speakers on and it would be nicer for the next person to have matched drivers.
Since the Sonora are made to order, I must wait at least 4 weeks for them to be built and shipped. Since the replacement drives are made to order as well and they don’t have any in stock so I must also wait about the same length of time. So it looks like the replacement drive units will arrive at the same time.
toocool4
« Reply #13 on: 16 Sep 2023, 09:53 pm »
One thing I missed out while talking about the Lino C is, to get even more out of the unit is you need to damp the case. The case rings like a bell if you tap the top, for me i am using HRS damping plate on top of the case to get even better performance out of the phonostage.
I have to say I use HRS on top of most things for improved sound, if you have not tried HRS damping plate go and borrow one to try out.
« Reply #14 on: 16 Sep 2023, 11:06 pm »
These Golden phonos are great, I wish some CD DACs had reached this level of refinement.
