thoughts on Fet Valve CF RB preamp?
jandrews
« on: 23 Jun 2023, 02:29 am »
Greetings
I noticed this preamp currently on offer via eBay and I'm just curious to learn more about it.
https://www.ebay.com/itm/204372965843?mkevt=1&mkcid=1&mkrid=711-53200-19255-0&campid=5338381866&toolid=10001&customid=60947028-1167-11ee-ba0d-376563653364
I have read the VA Audio Circle and there's not too much info about it specifically...the RB version that is.
I assume that this is just a RB version on the current Fet Valve CFR pre that is available from VA ... so the same audio circuits but no tone, filters, remote input switching, low/hi gain, etc.
Is that a correct assumption?
I'm curious how this pre would compare to the current RB10 that is available from VA and which I also own.
Is this audio circuit specifically a different sound presentation that the single 6922 per side equipped RB10?
Is it a lower noise circuit?  Is the main benefit of a  cathode follower a very low output impedance which would be better equipped to drive the next stage in the power amp?
thanks
avahifi
    • http://www.avahifi.com
Re: thoughts on Fet Valve CF RB preamp?
« Reply #1 on: 23 Jun 2023, 03:35 pm »
Yes, same audio circuits as the CFR but without all the bells and whistles.
A little bit more resolution and a little bit less “tube sound”.
Excellent value.  It is a couple years old.
Frank
jandrews
« Reply #2 on: 23 Jun 2023, 05:21 pm »
Thanks Frank
