Cheap and Cheerful Preamp With Remote
Doublej
« on: 19 Jun 2023, 07:56 pm »
What is your recommendation for a cheap and cheerful preamp with multiple inputs and a remote? No phono. Pre-crazy inflation guidelines would put the upper limit at $350 for it.
seikosha
Re: Cheap and Cheerful Preamp With Remote
« Reply #1 on: 19 Jun 2023, 08:44 pm »
I suppose the big question is do you need passive, or do you want a preamp with some gain.
Doublej
« Reply #2 on: 19 Jun 2023, 10:11 pm »
Definitely a preamp with gain. I could live with a single input if necessary.
jeffh
« Reply #3 on: 24 Jun 2023, 03:31 pm »
Great topic. Anybody have any recommendations?
Charles Xavier
« Reply #4 on: 24 Jun 2023, 05:30 pm »
Topping D50S iF DAC is needed
newzooreview
« Reply #5 on: 24 Jun 2023, 06:00 pm »
Schiit Saga S. $299
I haven't used it, but other things I've bought from Schiit has been very good for the price.
Comes in silver as well, and for $399 there's a tube option (Saga+)
« Reply #6 on: 24 Jun 2023, 07:31 pm »
Schiit makes good stuff.
seikosha
« Reply #7 on: 24 Jun 2023, 07:38 pm »
Unless you move up to the Freya, which really isn’t Cheap and Cheerful, none of the Schiit preamps have gain.  I don’t think the Topping does either.  Unfortunately, cheap preamps with gain and remote control are few and far between…I can’t think of any off the top of my head.  Maybe Parasound makes something.
