2B-LP transformer hum
0 Members and 1 Guest are viewing this topic. Read 3624 times.
GrooveControl
« on: 12 Jun 2023, 08:27 pm »
I have an older 2B-LP (non toroidal) with a fairly loud hum direcly from the unit, not the speakers. The hum is so bad that i can't use the amp in the house.  Even as a garage amp I find it annoying.
Back in the eighties I recall bringing such a unit in for service once, but all Bryston could do was tighten the transformer screws. I tried that on this unit, but that didn't help.
Forty years later...  has anyone discovered a way to solve the hum problem in these units without converting the transformers to the toroidal type?  I can't justify that cost, and am hoping for an inexpensive solution.
I read once about dipping the transformers in some sort of shellac, but don't have enough details.
Any thoughts?
James,   any magic bullet here?
GeorgeAb
Re: 2B-LP transformer hum
« Reply #1 on: 12 Jun 2023, 11:17 pm »
If the hum goes away when you float (remove from case and place on rubber mat, etc.) the transformers, I would look for non-flammable material to isolate transformer from case. Caulk, cork, rubber something like that you can put between case and transformer and then tighten screws enough to secure, but not tight enough to squash materal. If the hum is coming from transformer you are likely toast, but if it is the transformer vibrating the case something like this should work. I should state the obvious of do not handle transformers when unit is powered on and remember that those caps will hold a significant charge if there is no circuitry to bleed the current off.
John Tulett
  • Fascinated by vintage audio equipment
« Reply #2 on: 17 Jul 2023, 09:29 am »
To supplement the suggestions kindly provided by GeorgeAb, if the cause of the hum is the power transformer vibrating the chassis, to share something I found effective.
I recently restored my 2B power amplifier, documented in the Vintage Circle forum, "Bryston 2B Power Amplifier repair - Hints and Lessons Learned".  This unit was manufactured in 1978 having standard (non-torroidal) power transformers.
https://www.audiocircle.com/index.php?topic=184949.0
Although my 2B is fully operational after restoration and sounds great, with it connected to our AC supply of 50 Hz you could hear some background hum noise that I don't recall when it was previously operated on a 60 Hz AC supply.
While shopping at a local hardware store I found this product called CELLDAMPER made by INOAC in Japan.
https://www.inoac.co.jp/en/solution/celldamper.html
From their website, "CELLDAMPER is a foamed polyurethane elastomer developed for anti-vibration material to reduce oscillation. It is used in various fields such as civil engineering related, machine tools, and automotive fields due to its superior anti-vibration performance which was not able to achieve with the traditional foam."
A single 5 mm sheet cost me 3500 Yen, attached is the package label (in Japanese) with important information; Product Code BF700-53350, Dimensions 5 x 330 x 500 mm, Load Capacity ~ 6.0 kg / sq.cm.
The standard sheet width 500 mm was a good match for my 2B (or any 19-inch rack mounted equipment), just placed my 2B amplifier on top of the sheet, no cutting or trimming needed.
I then experimented with some simple sound level measurements using a third-party SPL app on my cell phone.
With the 2B amplifier powered on and warmed up, no audio signal just the background hum, cell phone placed in front of the amplifier with SPL Meter set to C Weighting, observed a repeatable 3-dB to 5-dB reduction in background noise level when the amplifier was placed on the CELLDAMPER sheet, compared to the amplifier on the shelf with no sheet.
Of course, this was no precision laboratory measurement, but it did show that the CELLDAMPER sheet made an improvement in reducing vibration noise.
While not an endorsement of any component supplier, the background hum noise is barely audible now so hopefully this may give some ideas what you could try.
Thank you,
John
Clive197
« Reply #3 on: 17 Jul 2023, 05:24 pm »
To me it sounds like a classic case of DC on the mains. Try a DC Blocker between mains and unit. There not expensive and can have great results.
GrooveControl
« Reply #4 on: 18 Jul 2023, 12:24 am »
Thanks for the input guys. The hum is there even when holding the amp in my hands.  There already is a rubber pad between the transformers and the top, but it doesn't help much.   I've had three encounters with the non toroidal version of this amp, and all exhibit the same problem.  I guess I'll hold out for a badly beaten non-working toroidal version and swap amp modules.
thanks
John Tulett
« Reply #5 on: 18 Jul 2023, 02:21 pm »
To share one more suggestion to investigate the audible hum, after an hour or so of the amplifier powered on, is the chassis hot to the touch?
This is what happened to me when restoring my 2B, initially I didn't pay enough attention to setting the output stage bias current, with the result the bias current was running high creating excessive heat generation and a noticeable hum noise from the power transformers.
Taking the time to correctly set the bias current brought down both the chassis temperature and the hum noise.
Here's a brief extract of what I posted in my report, "Bryston 2B Power Amplifier repair - Hints and Lessons Learned".  https://www.audiocircle.com/index.php?topic=184949.0
Measurements after repairs: "But if the surface is hot to the touch and/or the power supply is overloaded causing the chassis to hum then the bias current is likely running too high."
While I can't say if this is the issue you are seeing, with a decent DVM it's straightforward to check the bias value and the DC rail voltages - if the bias value is high or the DC rail voltage is sagging it can be related to excessive current in the power transformer.   When making these checks please be aware at all times of safety to equipment and yourself, when powered up there is both AC line voltage and DC rail voltages present.
Hope this give some ideas what to look for.
Thank you,
John
GrooveControl
« Reply #6 on: 24 Jul 2023, 08:49 pm »
just an update... I replaced the dense rubber pad on the inside top plate with a thicker 1/4" foam like material.  I don't remember where I go this material, but had it, so tried it.
It helped a bit.  now it sounds like I'm hearing just the transformers and not the transform interacting with the case vibrations.   While still not good enough for in house use, I can live with this in the garage.
« Last Edit: 25 Jul 2023, 08:43 pm by GrooveControl »
John Tulett
« Reply #7 on: 10 Jan 2026, 11:50 pm »
To share something interesting, I found the probable root cause of the mechanical vibration in my vintage Bryston 2B amplifier (manufactured 1978).
Removing the front 19-inch panel exposed the original tape and felt strips that had deteriorated/compressed over 4 decades.
After replacing these with new vibration damping material, the reduction in vibration noise was remarkable and it's now as I remember the amplifier when it was new.
This is documented in an update to the report "Bryston 2B Power Amplifier repair - Hints and Lessons Learned".
Please see section at the end of the report "Mechanical Vibration Reduction" with new Figure 10.
While I don't know if this fix has merit for your 2B-LP it could be worth a look.
Thank you,
John
REDGUUZ
« Reply #8 on: 12 Jan 2026, 09:41 am »
Hi John,
Thanks for this very helpful suggestion.
For Groovecontrol, it comes a little bit late (being an old 2023 thread) because he has apparently sold his (non toroid) Bryston 2-LP AMP, but currently he is apparently overhauling a few (1993's) toroid Bryston 2B-LP's.
He had a question on setting the Bias and I referred to your contribution  ( https://www.audiocircle.com/index.php?topic=193052.0 )
So we have gone literally "Full Circle" ;-)>
I had a remark though.
The Dutch Philips brand used to impregnate E-I transformers with a TAR Like substance  for use in the tropics.
The transformers were put in a vessel with molten tar (which was then put in an autoclave and pressure reduced to almost vacuum).
They were kept in this condition for say one night.
Thereafter, the  vacuum pressure was restored to atmospheric and the transformers cooled down .
 I saw the same technique of vacuum impregnating being performed in a Transformer workshop, but using a low viscous epoxy resim.
So maybe, owners of Bryston 2B and 2BB-LP 's ( with E-I Block transfermers) can ask a transformer workshop to apply this treatment to their transformers .
It will certainly eliminate mechanical hum.
Thanks again!
GrooveControl
« Reply #9 on: 13 Jan 2026, 04:23 pm »
Great info to have here. Thanks guys.
I no longer have a non-toroidal version of the 2B-LP, but if I ever get one on the cheap I might revisit these ideas.
Martin, I have one toroidal version and the parts you suggested in the other thread have been ordered from digikey.ca.  The WIMA caps are back ordered but expected today so hopefully I’ll have my order next week.
Looking forward to this.
REDGUUZ
« Reply #10 on: 14 Jan 2026, 02:42 pm »
Hi Groovecontrol,
Should not be a problem 4 you.
These amps are very easy to access.
For each channel: Just unscrew 4 screws on the corners of the heatsink and you can gently pull out the Printed Circuit Board.
Very easily serviceable!
I have 2 Bryston 2-LP amps (1991 and 1993 vintage).
1 Amp (the 1993 one, Serial #207634) ) had a very slight HF noise on One channel :
it appeared to be present on the Minus 45V Power Rail  (cearly visible on the Oscilloscope)..
I overhauled this Amp first.
The noise was very probaly due to the big 4700 uF 50V ROE Electrolytics and/or the tantalum (1.5 uF 35V) on that power rail..
(The noise moved with the PCB after swapping Left and Right Channel ). So NOT due to transformer and/or Rectifying bridge).
(The 3 pieces Nichicon (470 uF , 16V ) were still on speccs).
Of the 3 tantalums (1.5 uF 35V), the tantalum of the faulty powerline, ONE was off (1.425 uF), the other 2 still on spec ( 1.531 and 1.523 uF).
Recapping eliminated the noise.
Next, I recapped the second (1991 Amp Serial: # 205958) Amp.
This Amp was stilll playing OK.
The value of the big caps had been increased (5420 uF and 5465 uF) and they were starting to bulge.
(The 3 pieces Nichicon (470 uF, 16V ) were still on speccs).
The tantalum  on the negative power rail was 1.457 uF, the other two 1.523 resp. 1,525 uF)
(so maybe the one tantalum on the Minus Power Rail was also  deteriorating).
After overhaul, the amps only developed their full potential after playing for some 12 hours).
I'm really enjoying them!  Though little amps to survive 35 years!
Success with your overhaul!
Martin
mrhyfy
« Reply #11 on: 14 Jan 2026, 07:51 pm »
Just scrap the thing and get a new class d amp from amazon.
GrooveControl
« Reply #12 on: 14 Jan 2026, 11:56 pm »
I have two of those small FOSI amps, and must admit I was quite surprised at just how good they sound.  But the 2B-LP is such a beautiful hunk of metal that I will keep it even if unplugged, just to adore it. Maintaining vintage electronics has become a hobby for me since retiring.  Recapping is pretty easy and a lot of fun to do (at least for me).  Sure wish my unit had the 12V trigger, or even a power switch for that matter, but boy does it sound wonderful, and I hope to keep it that way.  If anything goes wrong with one of my small class D amps, well off to the dump it goes.
