Emotiva UPA-200 SOLD
0 Members and 1 Guest are viewing this topic. Read 744 times.
tortoiseman2542
« on: 12 Jun 2023, 01:17 pm »
Up for sale is a lightly used, one owner, Emotiva UPA-200.  Used in a bedroom setup with my Emotiva PT1 as a music setup.  Less than 200 hours of use and in excellent condition.  I do have original shipping boxes and can ship at buyers expense.
Emotiva UPA-200 - $200 OBO plus shipping
Specs
Topology: Fully discrete, dual differential, high current, short signal path Class A/B.
Number of Channels: 2
Power Output
(rated power; THD 0.05%):
125 watts / channel (8 ohms; all channels driven).
200 watts / channel (4 ohms; all channels driven).
Rated Power Bandwidth (at rated power; 8 Ohm load): 10 Hz to 20 kHz + / - 0.1 dB.
Minimum Recommended Load Impedance: 4 ohms (which equals one 4 ohm load or two paralleled 8 ohm loads per channel).
Frequency Response: 5 Hz to 80 kHz + 0 / - 2 dB.
THD + N: < 0.03%
Signal to Noise Ratio (8 Ohm load):
92 dB at 1 watt (A-weighted).
106 dB at rated power (A-weighted).
Damping Factor (8 Ohm load): 500
Speaker Output Connections:
Full-sized 5-way binding posts; one pair per channel x 2.
Power Supply:
350 VA high current ultra-low noise toroidal power transformer.
40,000 uF of storage capacitance.
Input sensitivity (for rated power; 8 Ohm load): 1.1 V (for full output; 8 ohms).
Gain: 29 dB
Input Connections:
Unbalanced (RCA); one per channel.
Input Impedance: 47 kOhms
Trigger:
Trigger Input: 5 - 20 V (AC or DC); < 10 mA input current required.
Trigger Output: 12 VDC; can drive any load up to 50 mA.
Power Requirements: 115 VAC or 230 VAC +/- 10% @ 50 / 60 Hz (automatically detected and switched).
Front Panel Controls and Indicators:
Standby; push button (changes color to indicate Standby or On).
Status LEDs (one per channel); illuminate blue for normal operation or red to indicate a fault (may be disabled by rear panel Status LED switch).
Rear Panel Controls:
AC Power switch; rocker switch (switches AC mains power).
Status LEDs switch; small slide switch on left rear (disables front panel Status LEDs).
Protection: The UPA-200 is protected against excessive operating temperature, shorted speaker connections, ground faults, and other common fault conditions. If a fault occurs, the UPA-200 will return to Standby mode, the Standby push button will light amber, and the Status LEDs will flash red.
Size:
unboxed: 17" wide x 3.375" high x 16.5" deep
Weight: 24 lbs (net); 32 lbs (boxed)
Features:
A true audiophile-quality stereo amplifier.
Advanced engineering with SMD gain blocks.
Wideband, short signal path, class A/B design topology.
Top quality parts and construction.
Real power easily drives complex loads.
Heavy-duty power supply with oversized toroidal transformer.
Gold plated five way binding post speaker terminals.
Gold plated RCA input terminals.
Classic Emotiva styling with rugged solid steel chassis.
15mm solid milled aluminum faceplate.
Channel status LED’s. (which can be disabled in stealth mode).
Remote trigger input and output.
115 VAC or 230 VAC with automatic detection and switching.
Full protection from all common input and output fault conditions.
Robert
« Last Edit: 2 Jul 2023, 09:04 pm by tortoiseman2542 »
tortoiseman2542
Re: Emotiva UPA-200
« Reply #1 on: 20 Jun 2023, 01:11 pm »
Bump and price drop...$225 plus shipping
Robert
tortoiseman2542
Re: Emotiva UPA-200
« Reply #2 on: 28 Jun 2023, 05:39 pm »
Bump and -rice drop…. $200 OBO plus shipping
tortoiseman2542
Re: Emotiva UPA-200 SOLD
« Reply #3 on: 2 Jul 2023, 09:04 pm »
SOLD
