Apple Remote Alternative (Apple has stopped making/selling old remote)
tortugaranger
    • Tortuga Audio
Hi All,
As you may know, Tortuga Audio has been using the 7-function silver aluminum Apple remote for close to 10 years now. Unfortunately, Apple recently discontinued the production and sale of that remote.
I've evaluated several alternatives and have selected a simple alternative 7-function remote that fully mimics the functionality of the Apple remote. The key differences between the Apple and the new Alternative are as follows:
1) Alternative is made of ABS plastic vs. anodized aluminum
2) Alternative is shorter, wider & thicker (and in my opinion is easier to hold and use)
3) The Menu and Play buttons are located above the circular 5 button control rather than below it
Both remotes use the same NEC IR protocol and generate essentially the same Apple command codes, hence no changes to the Tortuga Audio firmware are required to use the Alternative remote.
As with the Apple remote, you'll have to "pair" the remote to your preamp before the preamp will respond to the remote although you have 1 chance in 256 (0.4%) that your preamp will respond to any random new Alternative remote without having to pair it first. To pair the remote, press/hold in the encoder pushbutton on your Tortuga preamp for 20+ seconds until the unit enters "pairing mode" and then press any key on the remote. What happens during pairing is the preamp "learns and remembers" the ID of the remote which is some random number between 0 and 255.
You can buy a new alternative universal Apple remote from Amazon for around $11 (delivery excluded) - see link below. I will eventually sell these directly as well for a few $ more.
https://www.amazon.com/gp/product/B0C2VFHLW5/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
tortugaranger
    • Tortuga Audio
Since Apple is no longer making/selling its little silver/aluminum infrared remote, several alternatives have come on market. After trying several, I've settled on the 2 alternatives shown below because they're both affordable and readily available online.
The first one shown here is the "Function" remote. It has a nice high quality feel to it with a rubberized front. Buttons feel satisfying when pressed (never thought I'd say that). You can get one online for less but I'm selling them for $40. You can't use the Function remote with existing/older Tortuga Audio preamps or controllers. It will only work with the new V4 series going forward. Some buttons this remote have no purpose but that may change in the future.
The second alternative is the "Nettech" remote.  It's half the price of the Function remote. With only 7 buttons, it's an exact clone of the silver Apple remote and should be compatible with any Tortuga Audio preamp or controller board. Unfortunately, it has a cheap plastic look/feel to it and the buttons are a bit squishy. On the plus side, it's bigger than the little Apple remote and feels marginally better in the hand. At only $10-20 each, it's a bargain.
More info on the newer remotes here:  https://tortugaaudio.com/products/diy-preamp-components/remote-control/
mav52
Of course Apple is making their newer "  The Siri Remote (3rd generation) brings precise control to your Apple TV 4K "
Compatibility :
Apple TV Models
Apple TV 4K (3rd generation)
Apple TV 4K (2nd generation)
Apple TV 4K (1st generation)
Apple TV HD
Never know it might work @ $59.00
tortugaranger
    • Tortuga Audio
Compatibility :
Apple TV Models
Apple TV HD
I've not actually tested a Siri remote but the Siri primarily uses Bluetooth and is not universally compatible with older Apple TV/devices. The newer model Siri remote pairs with Apple TV HD (4th generation or later) (A1625 or later), not earlier models. The Siri Remote (2nd generation) requires tvOS 14.5 or later. The Siri Remote (3rd generation) requires tvOS 15.4 or later. The original silver aluminum Apple remote is infrared only. It's all a bit confusing when you start digging into the details.
tortugaranger
    • Tortuga Audio
Hi All,
With the release of Rev 2.2.0. of the V4 firmware, our preamps are finally cutting the chord with captive remotes like the Apple remote we used for many years (until they stopped making them).
Some background. With infrared remotes you have basically 2 choices.
Approach #1 - Pick one remote, program it's codes into your product and that's the remote everyone must use with your product. That's what we've been doing since day 1.  This works as long as the remote you picked remains available.  And you can always have a custom remote designed just for you and your product at great expense and now you're locked into yet another vendor.
Approach #2 - Pick any remote that uses the NEC infrared protocol and teach your product how to talk to it. Moreover, make it easy for your customers to do this themselves if they decide they want to use a different remote....or lose their old one.
Most infrared remotes use the NEC protocol so there are many candidates to choose from. We now promote the use of the Function remote available from the function101.com folks. They introduced this Apple remote substitute after Apple stopped making their little silver metallic remote. It's a nice quality remote and can be configured for a wide variety of devices beyond just Apple products. There are also really nice universal remotes these days like the SofaBaton.com series.
The way this new system works is you go to the V4 controller menu, scroll down to "Remote" and select it. This step puts the controller in remote learning mode so you are no longer giving the controller commands with your remote, you are teaching it commands associated with each control function. Since you can't use the remote itself to navigate through this process, you use the encoder instead. While in learning mode, turning the encoder switches to the next control function such as "Raise", "Lower", "Mute", "Power",  etc. For each control function, press the appropriate button on the remote 3 times in row. If all 3 presses generate the same code, that code is accepted and becomes the new code used by the V4 for that control function and the V4 will only respond to that specific "Raise" code going forward. Do this for each of the 7-10 control functions and you're done.
Existing V4's can be updated to work this way. The firmware update system for the V4 has not been published yet in our documentation but will be added very soon. Once it's available, I will post the updated firmware file for download.
Morten
nlitworld
And if you're ever house sitting for an audiophile friend and want to play a prank on them, just reprogram their remote functions to opposite of their intended button.  :lol: Harmless but maddening.
Pretty smart move though, to rethink user friendly interfacing.  :thumb:
tortugaranger
    • Tortuga Audio
Hi All,
I've published a knowledgebase "docs" article on the new "remote learning" feature of the V4 preamp controller.
You can access the article here:  https://tortugaaudio.com/docs/remote-learning/
As mentioned in recent post below, Tortuga has stopped using the old silver Apple remote as the official remote for Tortuga preamps. For the simple reason that Apple stopped producing and selling them. After some flailing, I settled on the Function101 remote as an acceptable alternative.
Starting with version 2.2.0 of the V4 firmware, we have removed all historical Apple remote "pairing" firmware and replaced it with generic remote "learning" firmware. The V4 preamp can now learn the codes of your remote provided it's an NEC protocol remote - most, but not all remotes, are NEC types. Any of the popular universal remotes like the SofaBaton brand will work.
But there are 2 issues with this.
First, the remote learning feature only works with the V4 model starting with the 2.2.0 firmware that was released on July 14, 2026. V4's with earlier firmware can only pair with an Apple compatible remote. Older V4's will need their firmware updated to switch to remote learning.
The bad news is, I discovered that the firmware updating system that had been thoroughly vetted and tested on the V4 during initial development, was later rendered inoperable due to last minute addition of a safety feature called a watchdog timer. To put it plainly, you can't update the firmware on V4's shipped up through early/mid July. You can send them in and I'll update them for no charge and pay for return shipping. After that, you can update them yourself.
Morten
