0 Members and 1 Guest are viewing this topic. Read 3753 times.
This is just playing around with pair(s) of crappy speakers. It will never sound good no matter what expensive parts get used.
It looks like buying the matching seperate high pass and low-pass would be cheaper than the two way. Thoughts?
Any impedance issues?
Two main issues related to impedance:1. If your drivers are low impedance and wired in parallel through the premade xo they might offer an impedance that is too low for your amplifier. A well designed custom xo avoids low impedance to the amplifier. 2. The load impedance on the crossover filter determines the filter's output function. Example: the same crossover filter on an 8 ohm driver will roll off at a different corner frequency than on a 4 ohm driver. And driver impedance is a curve that varies with frequency on any driver. A custom crossover can flatten the load impedance of a driver so the filter will function as expected, but a premade xo has no impedance correction.
If you have a 6 ohm driver, is it better to use a 8 ohm or 4 ohm passive crossover in a pinch?
