Industry Circles
Audio by Van Alstine
jimava
Using subwoofer with SET120 Control Amp
avahifi
Industry Contributor
21 May 2023, 06:38 pm »
A client suggested the following.
Get a 1/4” stereo phone plug. Connect two coax cables terminated with male RCA plugs. Connect from headphone output on the control amp to the subwoofer line level inputs. Adjust woofer volume to match main speakers.
A better solution is this:
https://www.showmecables.com/1-4-in-stereo-male-to-dual-rca-female-adapter?utm_id=361522565&keyword=&msclkid=5b37b96147f21ab2cca3dd0ae8f0e8fc&utm_source=bing&utm_medium=cpc&utm_campaign=(ROI)%20Shopping%20-%20Numbers&utm_term=4577266909614369&utm_content=Adapters
Instant set of line level outputs!
Frank
Last Edit: 22 May 2023, 07:02 pm by avahifi
TomBo
Re: Using subwoofer with SET120 Control Amp
22 May 2023, 03:45 pm »
Frank,
Very smart suggestion and it solves a question I had too. I will try this out. The headphone jack stays energized while listening through speakers! Now I see.
Thank you,
Tom
Lazeez
Reply #2 on:
1 Jun 2023, 12:02 am »
IF your subwoofer has high level inputs, you can use an extra stereo run of speaker cable from the amp to the Left and Right speaker cable inputs on your sub. Then adjust the crossover in your sub.
Industry Circles
jimava
