Bryston BR-19
0 Members and 1 Guest are viewing this topic. Read 2731 times.
Dawgneck
Bryston BR-19
« on: 30 Apr 2023, 10:51 am »
James,
Can you share detailed photos of the front and back of the BR-19 preamp, the input and output impedance, and share any additional details about the unit you're able to, like, does it come standard with a phono stage, etc?
I'm interested in matching it with the 28B3 that's connected to my Revel Salon2.
Thanks in advance.
Ray.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston BR-19
« Reply #1 on: 30 Apr 2023, 01:49 pm »
Hi Ray
Here is what I have so far.
The phono MM and MC will be an option.
Output impedance will be about 25 ohms. Have to ask engineering on the input but same as the Br20 I would assume.
best
james
Dawgneck
Re: Bryston BR-19
« Reply #2 on: 30 Apr 2023, 09:03 pm »
Thank you, James.
I can't wait to give it a run.
The USB and ethernet connections are for software updates, correct?
Re: Bryston BR-19
« Reply #3 on: 30 Apr 2023, 09:33 pm »
yes correct
james
HIFI Obsessed
Re: Bryston BR-19
« Reply #4 on: 3 May 2023, 01:21 pm »
Hi Ray
Hello James,Would the phono-stage  MM/MC be accessible for the owner to switch gains on the unit or would be set from factory?
best
james
Re: Bryston BR-19
« Reply #5 on: 3 May 2023, 01:56 pm »
The Gain will be set but will accommodate the majority of the MC's available.
james
bacmsl
Re: Bryston BR-19
« Reply #6 on: 4 May 2023, 04:31 pm »
Any idea on price?
Barry M
Re: Bryston BR-19
« Reply #7 on: 4 May 2023, 06:37 pm »
About 5K list
james
dbAle
Re: Bryston BR-19
« Reply #8 on: 6 May 2023, 12:45 pm »
Will the mm /mc phono option for the BR-19 work in the B135 cubed?
Re: Bryston BR-19
« Reply #9 on: 6 May 2023, 01:28 pm »
Its the same phono stage.
james
Stefan_DR3
Re: Bryston BR-19
« Reply #10 on: 10 Sep 2023, 05:08 pm »
james
Not sure anymore, James.  I was told by Mike that my BP17 Cubed phono module would not work in a BR-20 (so I sold it). Also according to the press release, the BP-19 phono is again different.
For the first time ever, Bryston is offering the legendary BP-2 moving magnet (MM) phono stage circuit as an onboard option for the BP-19 preamp
Re: Bryston BR-19
« Reply #11 on: 10 Sep 2023, 09:51 pm »
News to me - as far as I know its the same circuit.
james
