**Sold**HoloAudio Spring DAC Version 1 Kitsune Tuned Edition (KTE)
0 Members and 1 Guest are viewing this topic. Read 1084 times.
dcktr
HoloAudio Spring DAC Version 1 Kitsune Tuned Edition (KTE)– $1200
In Perfect Working Condition, there is a 2 inch linear smudge on the back right portion of the top that I could not capture with the camera. Otherwise I would have rated it a 9. Firmware is updated to the most current edition. I was original purchaser
This model is the fully loaded version with Silver transformer upgrade and Jensen Cap upgrades.
Patented R2R technology. This is the first discrete DAC that has linear compensation and this allows for ultimate music reproduction accuracy. Dual R2R network for PCM, and Dual Discrete optimized resistor network for DSD!
https://www.kitsunehifi.com/product/springdacgreen/
Has Been Upgraded with the HoloAudio USB Module (XU208 XMOS) found in Next level Spring DACS. This USB module supports the same input and output specs as the previous but with improved sound quality due to the newer XMOS. This module also has an improved clock as well as a few other minor improvements to the implementation. Customers have been thrilled with this usb module and will find it to deliver excellent sound quality. ($128) https://www.kitsunehifi.com/product/holoaudioxu208usbmodule/
I will also include the Titanis Active USB processor. Titanis is an active USB processor, and is different from the old USB filters which you may have tried before. The filter is composed of simple LC passive components, the output signal is all dependent on the input. Unlike others, Titanis is an active device, and the output is not affected by the strength of the input. ($98)
https://www.kitsunehifi.com/product/holo-audio-titanis-active-usb-processor/
Will include Shipping at asking Price.
Check out my perfect rating on Ebay
« Last Edit: 23 Apr 2023, 03:00 am by dcktr »
