Passion USB cable
0 Members and 1 Guest are viewing this topic. Read 8074 times.
Teojjsg
Passion USB cable
« on: 15 Apr 2023, 08:52 am »
Hi Pete,
My name is JJ Teo and introduced by Gavin from Singapore.
Can you kindly quote and sell me a Passion USB cable including shipping to Singapore pls?
I have sent you a few emails but no reply. Thank you.
Best regards,
JJ Teo
Triode Pete
Re: Passion USB cable
« Reply #1 on: 16 Apr 2023, 04:13 pm »
Hello JJ,
Please use “[email protected]” to contact me. My older email addresses do not work & I do not receive them.
As far as the “Passion” USB cables, I am experiencing supplier issues for the USB parts. Until this is resolved, I temporarily removed the Passion USB cables from my website.
Best regards,
Pete
Triode Pete
« Reply #2 on: 16 Jul 2023, 06:41 pm »
FYI, my supplier issues have been resolved and the "Passion" USB cables have been placed back onto my website... https://triodewirelabs.com/product/passion-usb-cable/
Pete
jandrews
« Reply #3 on: 16 Jul 2023, 10:09 pm »
Hi Pete
Is the μR-link USB constructed the same as the Passion USB currently being offered?
Jason
Triode Pete
« Reply #4 on: 17 Jul 2023, 01:45 pm »
Hi Pete
Jason
Hello Jason,
The "μR-link" USB cable is similar in construction but does not have the proprietary 3 pole power filter. The μR-link USB cable does not have the "trigger" as well...
I have a few "μR-link" USB cables in-stock even though they are not listed on my website...
Pete
jandrews
« Reply #5 on: 17 Jul 2023, 02:26 pm »
Thank you
Can you elaborate on what the “trigger” is? I don’t see it mentioned on the Passion description.
Also, what is the difference in case-use between the two? Assuming the Passion would be used from streamer to Dac and the μR-link would be used used a reclocking device?
Triode Pete
« Reply #6 on: 17 Jul 2023, 06:07 pm »
Thank you
The Passion USB cable is a full functioning USB cable with both data & power legs (with a 5V trigger), whereas the μR-link does not have the power leg, just the data legs…
jandrews
« Reply #7 on: 17 Jul 2023, 06:13 pm »
AndrewA
« Reply #8 on: 18 Jul 2023, 10:23 pm »
To connect a Schiit URD to a DAC, is it possible to make a USB cable type C to type B?
Triode Pete
« Reply #9 on: 21 Jul 2023, 04:14 pm »
Yes, it is possible...
Best regards,
Pete
