0 Members and 1 Guest are viewing this topic. Read 4404 times.
Using coax cable is not BS. It must be the correct impedance for the system that it is used in. If all the impedances are matched properly (which they almost never are), all digital cables sound about the same.
Cables that are 1/2 m and shorter almost always sound awful. Don't believe me? Go try it. I prefer something longer, in the 6 m range.
