Anyone who has listened to OB and DML, can you share the difference?
0 Members and 1 Guest are viewing this topic. Read 2332 times.
xsuper9988
Anyone who has heard of OB and DML, can you share the difference?
I mean in the mid-treble range
sedge
Hi xsuper.
https://tectonicproaudio.com/about-the-technology/
This link is a good simple description of the difference between DML and standard pistonic drivers.
They only do pro oudio, so use multiple exciters for higher power levels.
Steve.
xsuper9988
Hi xsuper.
Steve.
The result of this description is very real
Although I haven't actually heard of DML
but it's worth the wait
Thank you very much for your sharing and help
sedge
I also have a few videos on YouTube.
So hopefully you  an hear the DML sound for yourself.
@sedge3813.
I have a large selection  of different types of dml panels and sizes.
Please only  listen using good  headphones only,  this will give you the experience of actually being there.
These videos will only give an idea of what can be expected, the in room sound is far better .
I have made many recordings over on diyaudio,  but the forum is now over 500 pages which makes finding  them difficult, even for me.
I have just stopped using that site and am going to post some more YouTube videos, and ,hopefully,  they won't get lost ?
Steve.
sedge
I noticed you also liked the Audiofrenzy recordings, which are very good too,he gets a lot of stick because he will not show his panel designs, just the carpet  :D.
He uses EPS, which is also my favourite, but other types of panels can also work well ,all depending on your tastes and what you are used to.
Steve.
xsuper9988
@sedge3813.
Steve.
OK
sedge
Xsuper9988.
My next panels on YouTube will be my 5mm XPS panels coated in epoxy.
I will use the same music.
Steve.
