0 Members and 1 Guest are viewing this topic. Read 8587 times.
Phono cartridges?bottom Ortofon or GradoPhono pre-amps? VistaTurntables? find an old JVC QL F6 and pack the case with modeling clay- excellent motor, pretty darn good tonearm, crappy plinth
Rega Planar 1 Plus with built in phonostage.
https://www.audioadvisor.com/prodinfo.asp?number=OROM5EHow about this?
I'd spring for the 2M Red for the extra $20. Much better cart and it's upgradable to the 2M Blue later should you feel the need.As for built in phono stages, I'd rather go with a Schiit Mani before a built in within the C&C pricing region, and the Vista would be a big step up from that even. Much better options than the Rega 1Plus, but it sure is convenient. But you're not getting into vinyl for convenience...
Thank you, I passed it along to him.
https://www.crutchfield.com/p_057VM95E/Audio-Technica-AT-VM95E.htmlWas out of town. Drove by Crutchfield on the way home and bought this.
Cable: JelcoThis will set you back about a grand.
