VMPS Dedicated Sub - Passive Radiator
jklokk
« on: 7 Apr 2023, 07:40 am »
Greetings!
My sub needs a new passive radiator. The foam on the original has disintegrated. Any advice as to options?
ZAKski288
Re: VMPS Dedicated Sub - Passive Radiator
« Reply #1 on: 7 Apr 2023, 04:26 pm »
Welcome to Audio Circles jklokk.  Well you have a couple of ways of dealing with the passive, you can refoam the passive you have or replace with new passive.  CSS audio makes a great passive radiator APR 12.  Good luck Ken
Link for refoam kits:   https://www.simplyspeakers.com/rubber-speaker-repair-edge-kits.html
Link for new passive:  https://meniscusaudio.com/product/css-apr12/
                                 https://www.css-audio.com/online-store
jklokk
« Reply #2 on: 7 Apr 2023, 06:00 pm »
Doesn’t seem CSS has a 12” radiator. Thanks for the link though.
Any idea what these adhesives are covering the basket? Not sure if basket is the right word.
ZAKski288
« Reply #3 on: 7 Apr 2023, 06:52 pm »
Dampening material, keep the basket from transmitting noise.
The CSS APR12 is a 12” passive . The css link has not worked for me, that is why I included the the Meniscus Audio link
http://meniscus.lightningbasehosted.com/wp-content/uploads/2015/11/APRG.pdf
