Shure M97 vs Realistic/Shure model R1000EDT
Scott03
« on: 4 Apr 2023, 08:12 pm »
Hello,
Am wondering if the Realistic R1000EDT is the same as, or has a similar form-factor to, the Shure M97xE.  The Realistic looks as if it should fit on a Dual TK-14/TK-24 sled, and has the same connection lugs in back as the M97.
I ask because I have found an R1000EDT, in good shape, at a much better price than M97's tend to go for.  Am thinking of using it for playing questionable discs that I don't want to chance with my M97.  Check the disc visually, use a carbon-fiber brush, then play to see if it's sound and worth cleaning properly.
Turntable is a Dual 1245.  I would buy another sled, set up the R1000 properly, then swap cartridges as needed.
Thanks in advance.
