iFi iPhono2
0 Members and 1 Guest are viewing this topic. Read 1557 times.
iFi iPhono2
« on: 28 Mar 2023, 03:48 pm »
I just picked up an Ifi iPhono2. It has switches on the bottom to configure the cartridge being used.
What was the website that had every phono cartridge listed?
Pez
Re: iFi iPhono2
« Reply #1 on: 28 Mar 2023, 05:48 pm »
Re: iFi iPhono2
« Reply #2 on: 28 Mar 2023, 08:33 pm »
I remember there was this website that had all cartridges/styluses and their technical speciation. My cartridge came with the turntable when bought it used.
toocool4
Re: iFi iPhono2
« Reply #3 on: 28 Mar 2023, 09:07 pm »
If you cannot find the specs for your cartridge, just try as many combinations on the phonostage and pick the one that sounds best to your ears.
Not sure how old or what state your cartridge is in, you will need to replace it at some point. If it’s a MM you will need to replace the stylus and if it’s MC you will need to replace the whole thing, not knowing will make it’s replacement difficult. You are better off replacing it now with a known one and you will be able to set the loading properly.
Miney
  • Free your mind... and your ass will follow
Re: iFi iPhono2
« Reply #4 on: 28 Mar 2023, 11:18 pm »
Could you be looking for this?  https://www.vinylengine.com/
Re: iFi iPhono2
« Reply #5 on: 2 Apr 2023, 09:01 pm »
I got it set up.
Switches on:
MC
100
eRIAA
IEC
