BCD-3 Remote (BR-2?) - stopped working, suggestions?
0 Members and 1 Guest are viewing this topic. Read 883 times.
jneun
Greetings to all the smart folks.  Hopefully this is an easy one and someone has a ready answer.
I have a remote that came with my BCD-3.  Recently it went from intermittent operation to none at all. I've unplugged the player to no avail.  Any suggestions?
thorman
Re: BCD-3 Remote (BR-2?) - stopped working, suggestions?
« Reply #1 on: 14 Mar 2023, 12:23 am »
 Check the battery first !
lasker98
« Reply #2 on: 14 Mar 2023, 02:23 am »
Also check if any of the remote buttons are stuck in the down position. Common problem on my BR-2 remote.
jneun
« Reply #3 on: 14 Mar 2023, 01:14 pm »
Batteries replaced. Check!
I played with all the buttons and the remote started working.  Thank you.
colhogan
« Reply #4 on: 23 Mar 2023, 06:02 pm »
I just replaced the batteries in my remote after about a year
