The Brute
0 Members and 1 Guest are viewing this topic. Read 20477 times.
Sonnyhad
Re: The Brute
« Reply #100 on: 26 May 2023, 01:37 pm »
Hi all, I just purchased the brute and am going to start on the cabinets  next week.  Any advice is more than welcome.  I'll be cutting the mdf myself.
boac
Re: The Brute
« Reply #101 on: 26 May 2023, 05:00 pm »
@Sonnyhad Hoping you will share your impressions as far as sound quality after you're done with your build. Thanks
boac
Re: The Brute
« Reply #102 on: 28 May 2023, 03:58 am »
@mkrawcz btw, which KLH speaker do you have?
mkrawcz
Re: The Brute
« Reply #103 on: 28 May 2023, 11:47 am »
Model 5
Sonnyhad
Re: The Brute
« Reply #104 on: 30 May 2023, 09:20 am »
Does anyone know how large the crossover board needs to be?
mkrawcz
Re: The Brute
« Reply #105 on: 30 May 2023, 11:00 am »
I think I made mine 8in x 10in.
boac
Re: The Brute
« Reply #106 on: 30 May 2023, 06:23 pm »
@mkrawcz what's the dimension of the room the Brute's are in, mine is about 25 x 20 nondedicated audio room with some treatments
mkrawcz
Re: The Brute
« Reply #107 on: 30 May 2023, 11:43 pm »
Mine is similar 17x25.
boac
Re: The Brute
« Reply #108 on: 31 May 2023, 12:49 am »
Thank you. Do you use subs with the Brute?
Sonnyhad
Re: The Brute
« Reply #109 on: 31 May 2023, 11:13 am »
Thank you,  8 x 10 works fine. On to the mdf cutting now.
Sonnyhad
Re: The Brute
« Reply #110 on: 7 Jun 2023, 03:43 am »
Mdf cut and about ready to assemble.
BillZ260
Re: The Brute
« Reply #111 on: 5 Jul 2023, 06:54 pm »
Bought the Flat packs and ran into some trouble with the first cabinet during install.  Tried to build it all in one day, and had some issues getting everything to slide together right.
2nd one, I broke all sharp edges where bracing interacts, with a hand plane, maybe 1/32.  Built the top inner brace section only, attached the back, on day 1.  Let that sit and harden fully clamped and triple checking square.  Then Day two got the rest of the lower bracing, sides and top on much easier than trying to do it all day once.
Any other tips?
Ordered a second left :(.  And have the cross overs started.
Sonnyhad
Re: The Brute
« Reply #112 on: 11 Jul 2023, 01:47 pm »
one done almost done with the other.
Sonnyhad
Re: The Brute
« Reply #113 on: 11 Jul 2023, 02:15 pm »
Oh Dang it! I built it sideways!!  :)
mlundy57
Re: The Brute
« Reply #114 on: 11 Jul 2023, 02:37 pm »
You can lay on the floor for listening. Then everything will be good  :thumb:
Sonnyhad
Re: The Brute
« Reply #115 on: 11 Jul 2023, 07:37 pm »
Got 2nd one done and tested! They work! They work good! They work really good!
boac
Re: The Brute
« Reply #116 on: 11 Jul 2023, 09:29 pm »
How do they sound?
mkrawcz
Re: The Brute
« Reply #117 on: 11 Jul 2023, 10:01 pm »
Give them at least 100 hrs and they will open up a lot.
Sonnyhad
Re: The Brute
« Reply #118 on: 13 Jul 2023, 03:33 am »
I just have them hooked up in the garage for the moment to a Fosi v3 and already sound impressive. Then attached the eversolo a6 and wow not bad at all in the garage!  Oh the v3 does have the Spark op amp in it. Can't wait to put them in a listening area and better amplifier.
Sonnyhad
Re: The Brute
« Reply #119 on: 13 Jul 2023, 03:36 am »
They are keepers to say the least.  Very well done Danny!
