HAL Neutrik 4 pole connector mount for speakers
0 Members and 1 Guest are viewing this topic. Read 6576 times.
HAL
« on: 23 Feb 2023, 03:39 pm »
Servo sub cabinet Neutrik wiring connector mount
Talked with friend that is really good at 3D modeling and 3D printing.  Was looking for a way to mount the Neutrik 4 pole connectors for the wiring for the servo woofer in the 1x12 cabinet.  I use one connector per modular 1x12 cabinet to make it easy to move individual modules, so I can use either a 2x12 or 3x12 stack per side.
He made 3D printed Neutrik 4 pole mounts that allow the user to secure the wires to the mount.  The mount is screwed to the cabinet with countersunk wood screws.  The connector is secured to the mount with two machine screws, locking rings and nuts.  Color of the mount can be almost any color.
Anyone interested, they are available for $15/pair + shipping directly from HAL (Snail not included).
Contact me on AC messages for more info.
« Last Edit: 24 Feb 2023, 12:06 am by HAL »
HAL
Re: HAL Neutrik 4 pole connector mount for speakers
« Reply #1 on: 24 Feb 2023, 11:51 am »
Have updated the post with the introductory price of $15/pair for the Neutrik mounts.
Please let me know if there are any questions.
HAL
« Reply #2 on: 24 Feb 2023, 03:34 pm »
Here is the Neutrik 4 Pole mount with the connector mounted for reference.
Endo2112
  • Particularist
« Reply #3 on: 24 Feb 2023, 03:40 pm »
Great idea Rich,
Don
HAL
« Reply #4 on: 24 Feb 2023, 04:27 pm »
Don,
Sent an email to Jay with more info if needed.  :)
HAL
« Reply #5 on: 1 Mar 2023, 12:28 am »
Testing the colors out as received an order for 3 pairs in yellow, blue and green.
Will post pictures once they are ready.   :thumb:
HAL
« Reply #6 on: 2 Mar 2023, 12:50 pm »
Neutrik Speakon connector mounting hardware arrived.  Now I can mount the connectors in the subs for wiring. :)
HAL
« Reply #7 on: 8 Mar 2023, 12:24 am »
Received the #6 wood screws for the Neurtik 4-Pole connector mount.
Will be wiring the two latest H-Frame OB servo sub modules with these for the 14awg wiring.
sandbagger
« Reply #8 on: 20 Mar 2023, 10:39 pm »
Just printed Red,Yellow and Green mounts for someone, and yes that is not blue, its grass green, no idea what my pixel 7Pro just did to that color
« Last Edit: 22 Mar 2023, 01:23 pm by sandbagger »
HAL
« Reply #9 on: 21 Mar 2023, 01:29 am »
For reference sandbagger has these colors to choose from to 3D print the Neutrik Speakon connector mount:
mgalusha
« Reply #10 on: 21 Mar 2023, 01:48 pm »
Very cool. I made some little pucks to go under equipment with PLA and put a copper penny in the center for support.
HAL
« Reply #11 on: 21 Mar 2023, 04:05 pm »
mgalusha,
Glad sandbagger it so good with 3D printing!  It is amazing what can be done with 3D modeling and printing when you know how to do it!  :)
You are that way with metal projects!  I am happy when I can use a drill and not make a mistake! :o
