Problem with the DVA M225
driftingbunnies
« on: 21 Feb 2023, 04:18 pm »
Well maybe not so much a problem but how am I supposed to upgrade from this?   :scratch:
These monoblocks are such a solid product that I have no idea what could even replace them. They're small, quiet, cool, and sound great. If I want to upgrade to anything else, I'm looking at bigger, hotter, and quiet easily 2-4x more expensive.
Would love to get some help here. I'm completely lost where to go from here. Maybe I should hope for a M225 mk2?
BadDNA
Re: Problem with the DVA M225
« Reply #1 on: 22 Feb 2023, 12:30 pm »
Why the "need" to "upgrade"? Money burning a hole in your wallet? :wink:
If the amps are all you say, be happy..... don't worry!
aln
What did you have before?
« Reply #2 on: 22 Feb 2023, 01:35 pm »
Nt
mav52
« Reply #3 on: 22 Feb 2023, 02:56 pm »
Why even worry about. You like what you have. But there is always the DVA 750.
Don't worry, be happy
avahifi
    • http://www.avahifi.com
« Reply #4 on: 22 Feb 2023, 04:47 pm »
Well, you could always move up to our new DVA M750 mono amps.
Same sound, maybe even better, three times the power, just 60 percent higher priced, but more then twice the weight.
https://avahifi.com/collections/power-amplifiers/products/dva-m750-monoblock-power-amplifier
Frank
driftingbunnies
« Reply #5 on: 26 Feb 2023, 02:33 pm »
Frank
Frank,
Do you have a noise rating for the M750 vs M225? With the increase of power, will high efficient speakers start to have a slight hiss? Also, what's the Class A bias for the M750 vs M225? I know someone had mentioned 20w A for M225, is that the same for M750?
