Sonic Impact and Subwoofer
0 Members and 1 Guest are viewing this topic. Read 1277 times.
jakev2003
« on: 19 Apr 2005, 03:27 am »
Can I connect a powered subwoofer to this amp?  Do you guys do this?
orthobiz
« Reply #1 on: 19 Apr 2005, 10:13 am »
I just bought a REL B3. It comes with a cable that has three leads that connect to the same posts as the speakers: one to L & R hot leads, one to a ground. Should connect to any two channel amp!
biz
orthobiz
« Reply #2 on: 19 Apr 2005, 10:17 am »
Sorry! Just realized this is a multichannel forum. I'm talking stereo. The REL also has RCA jacks for multichannel bass output but this may not answer your question...
biz
ohenry
« Reply #3 on: 19 Apr 2005, 11:39 am »
You'll need to find an atypical subwoofer amp that doesn't tie the grounds for the two channels together.  I have to use a preamp output instead of using a line out from the amp.
tex-amp
« Reply #4 on: 21 Apr 2005, 02:36 am »
Quote from: orthobiz
biz
It is also the digital forum and the Sonic Impact is 2-channel.
