What solder station do you use?
0 Members and 1 Guest are viewing this topic. Read 2333 times.
Mikethehunterguy
Re: What solder station do you use?
« Reply #20 on: 18 Jan 2023, 01:01 am »
I use this unit from Parts  Express. I refurbish vintage receivers and need desoldering, too.
https://www.parts-express.com/Stahl-Tools-DSDS-Variable-Temperature-Digital-Solder-and-Desolder-Station-374-400?quantity=1
KTS
« Reply #21 on: 18 Jan 2023, 02:02 am »
I use a Weller Professional 260/200 for point to point soldering on crossovers. It heats everything fast, but the lights dim a bit when you pull the trigger. I also use some clip heat sinks to prevent over heating of the components. I have a smaller unit for more delicate projects.
