Cheap and simple LKS 004 Dac mods
bothandneither
« on: 6 Jan 2023, 04:03 am »
I am confident with soldering and desoldering, but I don't know anything about transistors, capacitors etc.. Is there anything cheap and simple I could do to upgrade my LKS 004?
Re: Cheap and simple LKS 004 Dac mods
« Reply #1 on: 6 Jan 2023, 11:34 pm »
Came to mind isolation foots or better C core transformers, not cheap.
bothandneither
« Reply #2 on: 7 Jan 2023, 02:42 am »
Oh the big round donut thing? Ya that would be easy to change out. How much would a better one be? I looked on partsconnexion and they had some for 100$ which isnt too bad
« Reply #3 on: 7 Jan 2023, 03:43 am »
Hardly a quality C core would cost this small.
Look some like Hashimoto C core power transformers:
http://www.tube-amps.net/Hashimoto_Products.htm
EMI/RFI shielding copper tape:
https://www.3m.com/3M/en_US/p/d/b40067901/
Speedskater
  • Kevin
« Reply #4 on: 7 Jan 2023, 01:58 pm »
Are there any serious test measurements for the LKS 004 ?
I found the  measurements, so:
Possibly the best modification is to sell it on e-bay.
Early B.
« Reply #5 on: 7 Jan 2023, 07:26 pm »
Yep. There's no point pouring more money into it. But if you insist, then spend a few hours scouring through this 292-page thread:  https://www.head-fi.org/threads/l-k-s-audio-mh-da004-dual-es9038pro-dac-van-dammes-double-impact.840938/page-288
and check out what Rick did to it:  http://tweakaudio.com/EVS-2/LKS_Mods.html
bothandneither
« Reply #6 on: 8 Jan 2023, 08:50 am »
Ha why do you say that? I was lookin to switch out for a Denafrips maybe or the Music Pegasus R2R, should I just hold out for those?
bothandneither
« Reply #7 on: 8 Jan 2023, 08:51 am »
These are awesome thank you!
