Maggie XO Mod survey
0 Members and 1 Guest are viewing this topic. Read 1390 times.
BikeFi10
« on: 3 Jan 2023, 05:03 pm »
Hope this isn't a burned out topic. Looking for next upgrade for 2023.
Ive read Maggie xo mods just make a different sound or its like taking ear muffs off or Maggies sound great as long as the rig is good, their properly positioned and room treatments are correct.
My 1.7i s would be difficult to xo mod as Ive moded stands that are mounted over sox and screwed into their wood braces.  Dan Richie said I could leave old xo in, access from fuse panel and leave new xo external.
Has anyone done that?
jbl
Re: Maggie XO Mod survey
« Reply #1 on: 4 Jan 2023, 02:25 am »
I used to have 3.7i's and replacing the stock crossover with an upgraded external one was one of the best mods I did to it.  A lot more clarity and a much more dynamic sound.
Not an easy mod as you have to partially remove the cloth sock and some elements of the factory xo but a worthwhile one.
audiobliss
« Reply #2 on: 6 Jan 2023, 10:49 pm »
Go to the Planar forum at AudioAsylum.com, and do a search.  Lots of info over there.
