Wr-100d
0 Members and 1 Guest are viewing this topic. Read 1876 times.
Quilbilly
Wr-100d
« on: 23 Dec 2022, 06:31 pm »
Last night my d-stream air app could not recognize my wr 100d player, and there is no option to configure it on the d stream app.
Everything has been perfect with this setup and my ida-8 since day one and now it isn't.
Can't find any discussions on this particular issue anywhere, so trying here.
Help...
Lol
Is there an option for a different streamer if I cany figure this out ?
Is DStream just defunct now ?
« Last Edit: 23 Dec 2022, 08:53 pm by Quilbilly »
rustydoglim
Re: Wr-100d
« Reply #1 on: 23 Dec 2022, 09:30 pm »
D-Stream has ceased operations for more than 2 years. If your WR-100D was working all along, and since there is no new firmware update, it might be the WR-100D has failed.
Quilbilly
Re: Wr-100d
« Reply #2 on: 23 Dec 2022, 09:51 pm »
Ok
It still acts the same, lights flash then goes steady as if connected to the wifi network.
Everything has worked fine since day 1, no changes.
What wifi streamer should I be looking at as a replacement then ?
I use Tidal hig res as my service and stream from my IDA-8, which I love btw...
My daily system for the last 6 years.
rustydoglim
Re: Wr-100d
« Reply #3 on: 23 Dec 2022, 10:40 pm »
Nuprime Stream Mini can be connected with a single cable to IDA-8 digital port (5V power + S/PDIF).
Quilbilly
Re: Wr-100d
« Reply #4 on: 23 Dec 2022, 10:45 pm »
Works with mqa tidal stuff then ?
Is there an app needed to run it ?
If so, where do I download the app for the mini ?
Sounds like what I need, but I am a bit challenged by tech at times.
rustydoglim
Re: Wr-100d
« Reply #5 on: 24 Dec 2022, 03:52 pm »
Omnia Stream Mini doesn't support Tidal MQA. The WR-100D doesn't support Tidal MQA either so what you have been listening is the Tidal HiFi at 16-bit/44.1K. Tidal has announced a new streaming format called MQair, which is supposed to be easier to adopt for hardware manufacturer.
giordy60
Re: Wr-100d
« Reply #6 on: 27 Dec 2022, 05:23 pm »
when you look for the w100d from the app .... at the bottom it doesn't ask you to connect it to an already existing streamer ?....
I did this last time.... and the app found my w100d
test if it works!
