Clari-T Upgrades
lushds
Clari-T Upgrades
« on: 16 Apr 2005, 08:56 pm »
I've just received my upgraded Clari-T back a couple of days ago.. The unit was upgraded with Blackgate caps and boy, I can tell you the improvements are not subtle!  Before this I felt the amp stuggles at higher volumes with my no so efficient speakers (~89db) - sounding rather thin and not so well controlled esp in the lower end.
With the BGs the 'thinness' is pretty much gone (Adamay - are you reading this) and the sound now is much more 'robust', 'bold' and has much better control in the bass department.  I know BGs are bastards to break-in - imaging is still a bit lacking and the HF/LF are still not as articulative - hope things will tighten up over time.
I felt that the BGs have also contributed to a harmonically richer sound with more texture.
For owners of Clari-T who want to take the already great amp to the next level - this is an upgrade I would highly recommended!!
toxteth ogrady
Clari-T Upgrades
« Reply #1 on: 16 Apr 2005, 10:32 pm »
Any idea what caps the Black Gates replaced?
lushds
caps
« Reply #2 on: 17 Apr 2005, 12:21 am »
I believe they were 2  low ESR Panasonic FC capacitors used for the power supply decoupling.
Rocket
Clari-T Upgrades
« Reply #3 on: 17 Apr 2005, 04:56 am »
Hi,
Blackgates can take about 200 - 300 hours to break in.  I had a digital amplifier and thought it sounded very thin but with the blackgates installed it dramatically improved the sound imo.
Regards
Rod
Vinnie R.
    • http://www.vinnierossi.com
Clari-T Upgrades
« Reply #4 on: 30 Apr 2005, 01:21 am »
All,
Below is a link to the Clari-T "Upgrades and Customization" page:
http://www.redwineaudio.com/Clari_T_Customization.html
Black Gates are just one of the upgrades to now choose from!  :P
Thanks for stopping by,
