Please advise me on next streamer
0 Members and 1 Guest are viewing this topic. Read 4832 times.
Kw6
Re: Please advise me on next streamer
« Reply #20 on: 30 Dec 2022, 12:14 am »
It's says 12v 1.8 amps. Can I use after market 12v 5 amp or what you say 9v. What's the difference? I am assuming if rates higher like 5 amps is ok as long as not under 1.8 amps. Am I correct?
JackD
« Reply #21 on: 30 Dec 2022, 12:32 am »
Either a 12 or even 15 volt is preferred over 9 volt. They were shipping them with 9 volt for a while and then found out it wasn't enough juice.
Kw6
« Reply #22 on: 30 Dec 2022, 12:54 am »
Ok I will stick with the recommended 12 volts. But do you have the jack size. Seems smaller than the standard 5.5mm-2.1mm that I see in all specs.
Kw6
« Reply #23 on: 30 Dec 2022, 01:23 am »
I found a 14.6 v 3 amp charger will this damage the Zen?
JackD
« Reply #24 on: 30 Dec 2022, 01:35 am »
It's 2.1 but I found out that the 2.5 will work it's just a bit loose as that's what it is for Aries Mini.
Kw6
« Reply #25 on: 30 Dec 2022, 02:39 am »
But when I use my ruler to measure it seems smaller than the standard 5.5mm OD and 2.1mm ID?
Kw6
« Reply #26 on: 30 Dec 2022, 02:41 am »
I better try the Zen first before I buy any aftermarket power supply!😂
JackD
« Reply #27 on: 30 Dec 2022, 02:57 am »
Test driving the unit before any expenditures is a good plan.  I already had the Aries PS which iFi said would work so I never even tried the one in the box.
Kw6
« Reply #28 on: 30 Dec 2022, 02:59 am »
What about this one from AliExpress same price as Power x?
JackD
« Reply #29 on: 30 Dec 2022, 03:08 am »
Wouldn't go over 15 volts.
Kw6
« Reply #30 on: 30 Dec 2022, 05:25 am »
Ok gotcha! In that photo is 12v 2.5 amps!
Kw6
« Reply #31 on: 2 Jan 2023, 02:47 am »
Set up Zen stream using spdif out to my SMSL D300 DAC. Sound is even more analog meaning less artificial sounding. Hearing more hall ambience retrieval. Sound has a certain musical ease. Will no more in a week. This assessment is only playing Zen for 30 mins from new out of box.
JackD
« Reply #32 on: 2 Jan 2023, 03:19 am »
It will get even better with more hours so if you have an unlimited plan put it on one of the FLAC radio stations in the iFi app and just let it play day and night for a while.  Upgraded power supply will also help a bit when you get to that point.  I tried mine into the Aqua DAC with the exact same model of Inakustik Coax and USB cable and couldn't point out any real difference so if you have a cable you like just stick with it.
Kw6
« Reply #33 on: 2 Jan 2023, 05:47 pm »
Thanks  for tips Jack! I have a nice 1.5m Wireworld Gold Elicpse coax. The power supply I'm using is in photo below. The Zen is slightly warm to the touch is that normal? I leave it powered on 24/7.
To me Zen seems music is more continuous less like chopped up bits! 😀
JackD
« Reply #34 on: 2 Jan 2023, 08:55 pm »
Yes it runs slightly warm that is normal.
Kw6
« Reply #35 on: 3 Jan 2023, 05:40 pm »
Thanks again Jack! This Zen stream has made me giddy as a school boy!🙊
JackD
« Reply #36 on: 3 Jan 2023, 06:33 pm »
Glad it's working out for you
Kw6
« Reply #37 on: 3 Jan 2023, 07:18 pm »
Thanks again for all your help and support! 😊
