0 Members and 1 Guest are viewing this topic. Read 5030 times.
By 'detail' I assume you mean resolution? I don't know if anyone wants more detail. To get the trifecta of better resolution, dynamics, and transparency (and who doesn't want all those?) I agree with Charles.Disagree with this. The A-21+ is the only thing I'd keep from that list of gear as it's more than capable of running the very difficult loads those speakers place on the amplifier. I'd sell everything else, not replace internal parts in equipment, and get the best source you can afford, possibly a dac/preamp that can run the A-21+. Apologies to the OP, this is what happens when you ask for advice.
I have the following components in my hi-fi system. And the sound has a dip in the vocal midrange followed by a peak in the treble then a roll off in the upper treble.But that roll off would be the Acoustats, as they naturally roll of at about 16k.TRANSPORTS & DACS-OPPO BDP - 105D DARBEE EDITION - THETA DATA II-TRANSPORT - THETA DSPro PRIME-DAC - PIONEER ELITE DV-45APRE-AMP - NUFORCE HAP-100 - HEADPHONE AMP/PRE-AMPPOWER AMP - PARASOUND - A21+ SPEAKERS - ACCOUSTAT SPECTRA 1100 ELECTROSTATIC - I also made some custom speakers using 15" professional bass guitar speakers-GRS PT5010-8 10" PLANAR MIDS -and GRS PT6816-8 8" PLANAR SLIM TWEETERS- While these sound better, there is still that thinness or dip in the midrange followed by a treble peakCABLES - KIMBER KABLE 8TC-3 METER SPEAKER CABLE - WIREWORLD-LUNA 7 INTERCONNECTS - HAVE CANARE 75 OHM DIGITAL COAXIAL CABLE - QED PERFORMANCE COAXIAL CABLESo, I figured that if I replaced the capacitors with much better quality ones starting with the Theta Data II CD Transport, that would cut out the harshness from the transport, smooth out the response and yet still be transparent and detailed. Then, if I still needed more refinement, I could do the same thing to the DAC. And then to the Pre-Amp if I need to.Because, I have tried over a dozen different interconnect cables. And while they do make a difference, none of them as of yet make a difference in the frequency range that I need to address. Not without knocking down the level of detail by quite a few notches. So, I think that upgrading the capacitors would cost less and have a much bigger impact on the sound.What do you think?
