really? my carmels are 16ohm though they are not fr.
Hey! OK, here's what I can see in that amp to answer your questions... the 100uf 160V is likely in the power supply high voltage B+ line and the 47uf 63V are in output tube bias caps. Yes changing those caps above will change the sound. But of all the caps in there, the ones that will have the most effect on the sound are those red WIMA caps, I think they are coupling caps which are directly in the signal path between input tube and output tube. According to the schematic in the link they are 100n or 0.1uf. There are lots of caps out there and each have their own unique sound even though they are the same value. The question is... what are you looking for? More transparency? But! If you like how the amp sound now, just enjoy it! Be careful what you wish for, sometime more expensive caps won't sound good in your amp. Sometime super transparency in audio is over rated. Most recordings out there are thin and bright so a little warm in audio is not a bad thing.
Great, the OPT must be 15 ohms.
According to the spec, it's wired for either 4 or 8?
Thanks Eric!Looks like I am in a good place regarding caps. I will concentrate on other aspects such as replacing the captive power cable.
technically these don't have captive cords... they have these connectors i've not seen before. it's rather chunky.
