Thin Fabric on Wall = HF Absoption??
0 Members and 1 Guest are viewing this topic. Read 2570 times.
mresseguie
« on: 2 Dec 2022, 02:42 am »
I visited an audiophile friend a few days ago. This guy is very much into tweaks of every kind. One thing I asked about was his hanging a very thin woven nylon-like material on the back wall directly behind the listening sofa. [Imagine a flag to get an idea of its thickness.] The guy insisted it was effective at absorbing some high frequency sound. I professed incredulity. He insisted he was correct. [He often insists his tweaks do this or that, and one had better be prepared for a knock down drag out argument if one wishes to disagree with him.]
Thoughts? Opinions?
Re: Thin Fabric on Wall = HF Absoption??
« Reply #1 on: 2 Dec 2022, 04:54 am »
Well it's better than a bare wall, but just barely.
« Reply #2 on: 2 Dec 2022, 05:15 am »
I have seen many eggs boxes in a garage studio wall, it dont work either, also shaggy rug dont damp to my ears, I have used 5mm black felt to some effect.
mresseguie
« Reply #3 on: 2 Dec 2022, 05:18 am »
Agreed. It is better than bare wall - especially considering walls here are six-inch thick concrete. One of these days I'll catalog all of his tweaks. There are plenty.
jtcf
« Reply #4 on: 2 Dec 2022, 05:28 am »
If there's a little bit of air space behind it, then it would have a small effect on the very highest frequencies. But only with reflections, it wouldn't damp anything.
mresseguie
« Reply #5 on: 2 Dec 2022, 06:37 am »
In your experience (anyone), would you say an inch of fairly lightweight foam is superior to two inches of rock wool?
Letitroll98
  • Too loud is just right
« Reply #6 on: 2 Dec 2022, 11:05 am »
No, not even close.  And I've used both.  4" of rock wool is very effective.  I have some heavy looking foam panels saved in my Amazon cart, very cheap, that have grandiose claims.  I don't think I'll ever pull the trigger, but I was curious enough to hit the save button.
« Reply #7 on: 2 Dec 2022, 01:52 pm »
Can't judge absorption material by description or appearance, must be measured across a wide frequency range.  Hard to find such measurements.  Doubt that thin fabric would make any perceivable difference.
mresseguie
« Reply #8 on: 2 Dec 2022, 04:10 pm »
The reason I asked concerning foam vs rockwool is because I told this tweaker (not to be confused with a trweker) that I finally got permission from my wife to put some absorption panels on the front and back walls. Rather than buying premade panels, I want to make my own using 4' x 2' x 2" roxul slices mounted on/in thin frames and covered in a fabric that my wife finds pleasing. The above mention guy told me that was unnecessary, and that I should just get 2'x2'x1" acoustic foam panels like he has. I insisted that I wanted better absorption, but he claimed foam is just as good. I stood my ground, so he recommended I buy premade GIK panels. Well, the GIK panels are about $50 each while 6 sheets of Roxul are essentially the same price. Hmm. Let's do the math. I buy Roxul, wood slats, glue and nails and inexpensive cloth....the total might come to $150(?) and I'll have six panels or four regular panels and four 2'x2' panels vs three GIK panels for $150. Hmm. Hmm. I've made these panels before, so I know how to do it.
My biggest question is why are the GIK panels so cheap compared to what they cost in the US?
Letitroll98
« Reply #9 on: 3 Dec 2022, 11:54 am »
Wow!  $50?  That's insanely cheap.  I must guess, assume, be pretty damn sure they're either knockoff or GIK has them manufactured there.  It can't be too hard to pull a couple staples and check the construction.  And it's also pretty easy to contact them here on AC and ask.
mresseguie
« Reply #10 on: 3 Dec 2022, 12:59 pm »
Just now, I referred back to the website where I found the ~$50 panels, and that price is no longer offered. I wonder if it was a Black Friday Deal? Dunno. [Yes, there were Black Friday deals here, too.] The prices that are listed now are $3500 NTD ($109 USD). The website is https://dimi.tw/store/product/gikacoustics-spot-panel-rectangle-ej038
I have no reason to think it's not real. With the $109 price per panel, I'm even more convinced the DIY approach is far better. Vicoustic panels are available online, but these are foam boards.
timind
  • permanent vacation
« Reply #11 on: 3 Dec 2022, 02:39 pm »
Building these absorption panels is a fairly straight forward task if you have the materials, space, and the least bit of skills. I used pieces of 1x4 to build the frame. For me, the most difficult part of the task is applying the fabric as neatly as the pros.
mresseguie
« Reply #12 on: 3 Dec 2022, 02:58 pm »
Nice to 'see' you! I was going to type that I haven't seen your posts in a long time, but noticed you have been posting. I'm an hour's drive from the best acupuncturist I have ever been 'stabbed' by. Her needles relieve my tinnitus and my hyperacussis, but I have to keep going or they slowly return.
Yeah, the fabric can be a bitch. I'll need a staple gun. I may hire a seamstress here to make me a few extra-large 'pillowcases'. Hmm. I wonder...
