Available for demo/sale Nu Force Switching ANALOG Amplifiers
0 Members and 1 Guest are viewing this topic. Read 1135 times.
cryotweaks
  • Funny name. Serious audio.
    • TweekGeek.com
http://www.tweekgeek.com/images/Payment_Banner.jpg" width="468" height="60">
http://www.tweekgeek.com/images/NuForceLogo.jpg" width="750" height="50">
Experience a revolution in switching amplifier design that rivals and surpasses most linear and tube amplifiers
http://www.tweekgeek.com/images/NuForceRef801.JPG">http://www.tweekgeek.com/images/NuForceRef801_th.jpg" width="429" height="384" hspace="5" border="0" align="right">
Email [email protected] to get on the in-home demo list!
http://www.nphysics.com/whitepaper-scc.htm" target="_blank">Technical info
Winner of a CES 2005 Jimmy Award from http://www.soundstageav.com/onhifi/20050115.htm" target="_blank">Soundstage
  "...The sound they evoked from an old pair of Sound Dynamics loudspeakers was downright voluptuous...." - http://www.soundstageav.com/onhifi/20050115.htm" target="_blank">Soundstage
My first impressions from listening to a pair of NuForce™ amplifiers was the incredible speed, smoothness at all volume levels and power they posessed. Then I really started listening. The harmonic structures were clearer, the soundstage was better, the listenability factor was greater than any amp I have ever owned or listened to before.
All this from a 3 pound amp?
        Don't be fooled by the "heaviness factor" of amps any longer. Most of the weight (and many of the problems) with conventional amplifiers are the power supplies. In a typical "heavyweight" amplifier, you will find a large transformer. That basically is what supplies the current, that gives your amp its musical muscle. The problem is, next to the Nu Force switching power supply, the transformer based power supply is slooooow. Not just on the rise, but on the fall. Once that dynamic peak is over, that big transformer cannot recover fast enough, and ends up hurting the audio signal. Skeptical? Try a Nu Force amp in your own system and see if it doesn't supply better transient speed, and (at least) equal force than your heavyweight, megabuck amp.
NOT a Digital Amp
        NuForce developed its revolutionary amplifier technology from the ground up to tackle absolute and faithful music reproduction. NuForce amplifiers offer unparalleled high bandwidth (unlike class D amps), with virtually no phase-shift in the audible frequency range. Therefore all audio frequencies ant their pitch-defining harmonics are faithfully reproduced. Additionally, the output stage is fully regulated providing an extremely high damping factor (exceeding 4000) which ensures tight, articulate bass reproduction.
No other solid state amplifier could compare with NuForce Analog Swtching Amplifiers™. While the best of vacuum tube amplifiers may share the pristine midrange reproduction similar to NuForce amplifiers, they inevitably have attenuated high frequencies, phase shift errors, and do not have the bass control or resolution.
The Reference 8 puts out 140W into 8 ohms while retaining its 0.05% THD+noise rating from 10Hz to100kHz, from first watt to last.
Specs
Power/Load8 ohm4 ohm2 ohm
Peak Power (20 msec hold time)288W576W1152W
Avg. Power per Cycle144W288W576W
Continous RMS Power100W100W100W
http://www.tweekgeek.com/images/NuForceRef802.JPG">http://www.tweekgeek.com/images/NuForceRef802_th.jpg" width="192" height="256" hspace="5" border="0" align="right">*Continuous RMS power is the maximum continuous power of the power supply and it is constant
  • Power bandwidth: 10 to 100,000 Hz +/- 3dB
  • THD+N < 0.05%, 1W to 100W, 1kHz
  • Internal wiring: silver plated mil spec teflon power wires and silver speaker wires
  • Cardas RCA & patented rhodium over copper binding post
  • Chassis is completely made of high grade brush and anodized aluminum to reduce audio resonance
  • Dimension: 6.5" x 10.5" x 1.75"
  • Worldwide AC voltage (84VAC to 264VAC). No need for AC regulator if the AC voltage falls within the specified range.
  • Weight: 3 lb
TweekGeek will only sell to individuals without a local dealer in their area.  Please support your local audio shop!
  • Speakers....What Speakers ?
« Reply #1 on: 16 Apr 2005, 04:18 am »
Hello Mike,
    I'd be interested in your impressions of a NuForce and SP Tech Timepiece's matchup. Will you be able to try that combo out ? Thanks !![/list:u]
      Chris[/list:u]
cryotweaks
    • TweekGeek.com
« Reply #2 on: 16 Apr 2005, 03:09 pm »
Yes I will, but not until June or so when more amps become avaialble.  I need to get the amps I have out for demos, and the Timepiece's new crossover and tweeter haven't arrived yet.
