Audio/Video Gear and Systems
The Acoustics Circle
Rob Babcock
NU-Foam vs. Open cell foam for sound absorbtion
0 Members and 1 Guest are viewing this topic. Read 1527 times.
lupodwdm
15 Apr 2005, 07:05 am »
Question:
Which would be better for treating the inside of speakers cabinets? Plain old open cell foam, or NU-FOAM which says it's comprised of highly compressed layers of polyester. The open cell soft foam they have is like the stuff you would put on your bed, the NU_FOAM is like the foam you would use outdoor in the padded seats of your padio set. Here's a link to NU_FOAM:
http://www.hancockfabrics.com/jump.jsp?itemType=PRODUCT&iProductID=8757
I can get both types at walmart, but I'm not sure which will work better. I seem to remember seeing some polk audio speakers lined with something that looked very similar to nufoam.
Thanks for th help!
8thnerve
15 Apr 2005, 12:58 pm »
I am not familiar with Nu-Foam, but it looks like it is not an open cell material, which would make it completely useless. Usually a shinier surface is a sign of a closed cell material.
lupodwdm
Reply #2 on:
15 Apr 2005, 08:43 pm »
The nu-foam is like Dacron. I've been told by a source that 1" dacron will work quite well. BUt I'd like some other opinions.
Rob Babcock
