0 Members and 1 Guest are viewing this topic. Read 2522 times.
Roon will do this.
Raspberry Pi sounds like what you are describing: little boxes on the network accessing files on a disk/file server somewhere on the network.You can put Moode on a Rasberry Pi and get digital out to a DAC. You would almost certainly want to put better digital output on the Raspberry Pi, so something from Allo would be a better choice than a bare bones Raspberry Pi.https://www.allo.com/sparky/katana-player.htmlThere is no free version of Roon. Raspberry Pi streaming was hit and miss for me with hi-res files (e.g., 192/24 tracks) even via ethernet.If you are just going to move a laptop around and plug a USB DAC into it, then you just need something like VLC (free) or Foobar. They will probably identify at least 80% of your library and grab album art so it won't be a completely miserable experience.Sound quality with the free options will be ok for background music and general non-critical listening.Other than having FLAC files on a computer, the rest of your use case is unclear.
JRiver will allow you to do all you want. For one, one-time price, you can download the software to multiple devices, hooks up to the internet and allows you to stream services.
Control is through the Alexa voice interface…
I think a stack of Amazon Echo Dot 3's will do it for you and provide streaming services too. Price is $15 each on Cyber Monday special. Take the analog output on the Dot and feed it to an input on each of your systems. Control is through the Alexa voice interface on the Echo Dot or an Alexa app which is supported on Windows, Android, iOS, MacOS and (I think) browser.For higher audio quality you should be able to substitute a WiiM Mini for an Echo Dot 3 at $80 each and use the WiiM SPDIF out to feed a DAC. It's analog output is likely better than the Echo Dot 3 as well. If you want a hardwired Ethernet connection there is a WiiM Pro at $150, coming soon.You'll need to do a bit of research to determine how to setup an inhouse music server for use with Alexa. I think you can use a Plex Server or a DLNA server. You might find that the WiiM will work better for serving up your internal collection of music.Darko Audio has a number of YouTube episode on streaming digital music collections, whole house audio and related topics.
With WiiM, can I disable Alexa and only use a DLNA server? I do not have (I have disabled all types of assistants from all my devices that I can) nor do I want Alexa, or any of the equivalents on my network.I have watched a Darko Video on Squeezebox, and this is what started me to consider this, again. I thought I would check here to see what other options are available.
I am an audio hobbyist. I have about 6 systems mostly analog throughout my home. I also have ~6.600 flac files (I also have quite a stack of the original CDs) on a computer on my network. My goal is to be able to easily access the FLAC files from any of the systems. I could move a notebook computer from system to system, and I do this sometimes.What I would really like is multiple small inexpensive device which I can plug into all of the systems which I could control from a PC, tablet or phone (Android, I do not do Apple and will not have any in my home). They would then need to talk with some flavor of a media server running on Windows.Streaming from services would be a nice add-on, but I do not have any subscriptions at present so it is not a requirement. I have a secure WiFi network everything would run on. I have wired ethernet to a number of the locations as well. I should have started doing this 20 years ago, but here I am.What recommendations are there based on the above? I am not afraid of technology, but since I work with it daily, I prefer not to get up to my derrière in it as part of my hobby, so simple is good.
