XLS Build
0 Members and 1 Guest are viewing this topic. Read 5450 times.
Wigand
Re: XLS Build
« Reply #20 on: 4 Feb 2023, 07:48 pm »
Hm that could be. I will round them over a bit. The middle pole I already build as a 3/4x3/4 without roundings as there was nothing mentioned in the plans.
Wanted to ask about something else. One tweeter I got to fit really snug without any visible spacing arround. The other has - if placed right in center like half a mm space arround. That should be nothing to worrie about right?
Lol I am also kinda picky about that stuff.
Peter J
  • Hmmmm
Re: XLS Build
« Reply #21 on: 4 Feb 2023, 09:15 pm »
I think some space is a good thing. I like to increase cabinet flange recess .020-.030" from actual measured dimension. Finish of any type can easily build to .002-.005 making a snug fit raw too tight. I've filed driver flanges in some cases because it's easier than increasing diameter of flange recess.  If finishing in lighter color, I often run a black felt tip pen on vertical wall of recess to create a shadow in that area. I don't like seeing a light ring around driver and just darkening it makes it nearly invisible.
Wigand
Re: XLS Build
« Reply #22 on: 6 Feb 2023, 06:40 pm »
Quick question; the smaller torx screws.... are they for the tweeter or for the back terminal cup?
Crossovers final assembled :)
Hobbsmeerkat
Re: XLS Build
« Reply #23 on: 6 Feb 2023, 06:43 pm »
Back cup. You'll want similar size philips screws for the crossovers
Wigand
Re: XLS Build
« Reply #24 on: 6 Feb 2023, 06:52 pm »
Sweet; will put the norez in today. I am so excited.
Sadly my Amp will arrive no sooner than tomorrow. So no listening today.
Wigand
Re: XLS Build
« Reply #25 on: 6 Feb 2023, 06:54 pm »
Hehe
Re: XLS Build
« Reply #26 on: 6 Feb 2023, 06:57 pm »
Ready for action!  How are you going to finish them?
Wigand
Re: XLS Build
« Reply #27 on: 6 Feb 2023, 06:59 pm »
Matt black I think. But I can do that anyhow. Have not really thought about that too much.
Wigand
Re: XLS Build
« Reply #28 on: 6 Feb 2023, 07:00 pm »
I spend more time thinking what caps I want to put in there finally.
Maybe you can relate tyson ? or maybe not haha
Re: XLS Build
« Reply #29 on: 6 Feb 2023, 07:02 pm »
If it was me, I'd do Miflex copper caps but that's not exactly easy on the wallet :P
Wigand
Re: XLS Build
« Reply #30 on: 6 Feb 2023, 07:06 pm »
Yeah that’s a bit too far. Also I definitely don’t want to go for an external crossover.
Will definitely do Miflex bypass eventually. The main caps I have not decided on.
And then maybe mills instead of the daytons.
But for now I am really happy. The crossover in this configuration looks already soooo much heaftier than anything or almost everything commercial available.
Wigand
Re: XLS Build
« Reply #31 on: 6 Feb 2023, 07:07 pm »
Also it’s a bit unfortunate that the one tweeter cap is a 2uf instead of a 2,2 or 1,5 and almost no cap brand Carrys 2uf
Re: XLS Build
« Reply #32 on: 6 Feb 2023, 07:28 pm »
You can use 2.2 it’s close enough.
Wigand
Re: XLS Build
« Reply #33 on: 6 Feb 2023, 07:32 pm »
Ah sweet; but thats in the future anyways. But thanks Tyson.
Re: XLS Build
« Reply #34 on: 6 Feb 2023, 09:28 pm »
Other caps worth considering in the future would be the Janzten Alumen Z cap, which sounds very good and is less expensive than the pure copper foil caps.
Wigand
Re: XLS Build
« Reply #35 on: 6 Feb 2023, 09:46 pm »
Lol do you read my mind???
That was exactly what I had in mind. Alumen on the TW and Clarity CSA on the woofer because I ready that the two match very well and the alumen dont come in 12uf.
Than Miflex bypass on everything. Path Res for the TW and the coild I would leave with the ones from danny.
But this is all future hehe.
corndog71
  • Some people call me Rob.
Re: XLS Build
« Reply #36 on: 7 Feb 2023, 03:27 am »
I recently acquired another pair of X-SLS built by AV123.  All stock.  I’ve been thinking about upgrading the caps and considering Clarity CMR/ESA or going all out and getting V-Cap ODAM.  Also Miflex bypasses.
Wigand
Re: XLS Build
« Reply #37 on: 7 Feb 2023, 08:38 am »
BTW I was wondering; what would it actually do to put a 2,2uf instead a 2uf on the tweeter… like Tyson said it’s a minor change but I would be interested what tendency a larger cap in general in that spot is effecting the response :)
Just curious
Hobbsmeerkat
Re: XLS Build
« Reply #38 on: 7 Feb 2023, 01:04 pm »
It will lift the very top octave of the tweeter a little higher.
Maybe 1/2 a dB?
tortoiseman2542
Re: XLS Build
« Reply #39 on: 7 Feb 2023, 04:05 pm »
What veneer????  I've been trying to find a pair in Moho for years.
Robert
