Finding the correct front speakers
0 Members and 1 Guest are viewing this topic. Read 969 times.
PhillipR
« on: 27 Oct 2022, 01:41 pm »
I’m stuck.  I have a 17x17 room with 11’ ceilings.  I sit about 14 back from the speakers / TV.  I’m trying to find a good pair of front speakers that I can place right next to the wall (they’d sit on a shelf).  I’m happy to make any tweaks / modifications to he speakers.  I don’t use them to listen to music, only movies.  I have two subs (speedwoofers).  Budget <$800 ideally.
What speakers should I consider / recommend?
Thank you very much.
Re: Finding the correct front speakers
« Reply #3 on: 27 Oct 2022, 06:11 pm »
If you don't mind DIY (assembling a flat pack), these are a good choice - https://gr-research.com/product/x-bravo/
