Burning in Capacitors
S Clark
« on: 20 Oct 2022, 07:47 pm »
I've got a couple of MIflex Cu and several Mundorf Silver in oil and SilverGold in oil of different values that I need to burn in.  I'm going on vacation in a few days.
The plan is to strap them all in parallel to about 17 uF, put in front of a midwoofer, and leave it playing radio white noise.
Any issues with this plan?
Speedskater
  • Kevin
Re: Burning in Capacitors
« Reply #1 on: 21 Oct 2022, 12:24 pm »
A lot of amplifiers won't be happy with that load.
Note that film capacitors don't burn-in like electrolytics do.
S Clark
« Reply #2 on: 21 Oct 2022, 12:27 pm »
I'm curious.  The midwoofer is 8 ohms across a full range.  If I put the caps in front of it, the load doesn't go down. If anything it should go up.  Nothing is in bypass to the circuit.  Why is this a difficult load?
I hope you see this soon.  Leaving in a couple of hours.
« Reply #3 on: 21 Oct 2022, 01:11 pm »
Any storm on the weather forecast.
S Clark
« Reply #4 on: 21 Oct 2022, 01:58 pm »
Good question.  The fall season in west Texas has few storms.  We should be fine.
