0 Members and 1 Guest are viewing this topic. Read 1947 times.
And will there be any advantage at all in buying a $5000-$10000 DAC when connecting an ADC/DAC later in the chain?
The follow on question is who makes digital crossovers that accept digital inputs and do their products support hi-res digital?
If you look at the upcoming Danville Signal dspNexus 2x8 digital crossover at their webpage, they support USB Async and S/PDIF style digital input and outputs. They process internally at 32bit/192KHz for the DSP crossover and use AKM A/D and D/A converters with 24bit/192KHz conversion for the system. The prices is supposed to be $3000.00 when released. Best info I have at this point.Here is the website:https://danvillesignal.com/dspnexus-dsp-audio-processorHope that helps.
Avoid the extra d/a conversion. The best active systems I've heard are DEQX based.
