0 Members and 1 Guest are viewing this topic. Read 2369 times.
I take it that you have ruled out it being a cable (interconnect and speaker) issue by swapping around cables. If your gear will not blow up with the following suggestion I would try this:Take a single channel (Left or Right) from the VAC and feed it to single channel (Left or Right) of the PASS. Note how it sounds. Now switch the input to the other channel of the PASS. If both times it sounds good or bad, it is the VAC that is broken. You can confirm this by repeating the test with the other channel of the VAC. You should get the opposite result with both channels of the PASS. If sound goes from good to bad or bad to good when you feed the same channel from the VAC to different channels of the PASS, it is the PASS. Alternatively, you could feed the analog output of a computer (headphone jack) to the PASS. If the VAC is broken, both channels will now sound good. If the PASS is bad, then the bad channel will still sound bad and the good channel will still sound good.
it needs to warm up for a day so it's big whatever it is. It's not a cable or source.
